HID Kit for 2020 Kia Telluride S
tdavila0821
Hi All,
Has anyone installed an HID kit in a 2020 Kia Telluride before? I saw a couple of older posts from 2019 and 2020, but I believe they were for the EX. I tried to click on the Amazon links, but they were expired. I appreciate any guidance!
Hi All,
I just installed led bulbs in my 2020 s model. Has been working fine.
Hi Diep,
You install an HID kit? If so, can you share the link to the product?
No I installed led bulbs only. They are brighter than stock halogens but not as bright as hid.
Hi Diep,
I had a friend that did and the only thing he had to modify was the moisture cap. He ended up drilling a hole to run the wires out and then sealing it up. He bought an extra set of caps to test run and in case he either messed up, or changed his mind. The project worked well and the visibility was better.
That's a good idea. Thanks!
I did a stealth install of Morimoto Elite 5k HIDs on my 2022 s.
Thread 'Stealth tellurideforum.org/threads/stealth-hid-installation.9993/
