Outside mirror issue.
robertabba0
I Have a 2024 EX model bought new.The right outside mirror tilts down by itsel.Does anyone else have this problem?
If you leave the mirror control on the driver's armrest in either the left or right position, the mirror is supposed to tilt down when you are backing in reverse. Is that what you're asking about? If so, just put it in the middle position and it will stop doing it.
I do not believe it is supposed to do that on the EX model.Also,the drivers side does not do that.
If you have the right package, putting the truck into reverse when the mirror switch is in the L or R position will move the mirrors.
With the truck in reverse, you can set the position of the mirrors for reversing using the usual mirror controls. When you get it where you want, save the settings. After that, each time you put it into reverse (with the mirror switch in L or R), the mirrors move to your preset location.
So, what the OP might be seeing (if they have the package and it's not something else) is that someone set the driver's mirrors to the normal position when in reverse (and saved it) so it won't move.
2024 Kia Telluride here - less than 1000 miles - Since it was new - we have not been able to get the right side mirror to keep a setting. You set it and save - reverse or go forward, and it tilts down - even in middle position.
