Hi Everyone,
After fighting this problem for two years since the day my Telluride was new (2022), I thought I'd ask others on this forum for some help; 2 dealerships are not able to figure this out. While driving approximately 3 car lengths behind someone and going the exact speed as the vehicle in front me, the following message mayl pop up on my display:
Foward Collision - Avoidance Assist (FCA) system Disabled.
Radar blocked.
I say "may" because it happens sporadically.
There is nothing blocking the radar. After about 5 min, the message will go ahead. If I happen to be using cruise control, then I get this message:
Smart Cruise Ctrl, conditions not met
This disables the cruise control.
Two different dealerships said they cannot help because no codes/message are found when they hook up their obd2 scanner. I was told to drive around...and when it comes on, quickly drive back to show them. One dealership kept the car for a full week and could determine the issue.
It was suggested that I buy my own obd2 scanner...so I purchased Motopower Mp69033. I kept it hooked up to my telluride. I was making a 200 mile trip and wanted to see what error I could get. I got the blocked radar message 9 times during that trip, but no codes showed up. It seems the device that's causing the issue in my car is not sending an error code of some kind. Would replacing the radar sensor correct it? Has anyone else had this issue? Maybe someone had, but I did not pick it up while searching for it.
Thanks, Tom
Radar blocked.
Thanks, Tom
