Miles per tank
Angie82
South Bend, IN
Is there a way to see how many miles per tank you drove? I'm hoping I am just over looking a setting. Right now after I fill up the display tells me what I should get out of a whole tank but what am I really getting? I owned a Toyota Venza prior to my SX AWD Telluride and it had a trip 1 and a trip 2 that I would alternate resetting after each fill and I could see exactly how many miles to the tank I got. Where is the trip setting and can I make this a constant display so I can always see it?
For the Tellurides, it comes with Accumulated info and drive info. Drive info display is reset on every drive, or once-a-day, or every fuel fill-up depending upon what option you select.
I generally reset the Accumulated info tab and use that to see how many miles I'm getting per tank.
How do I access the "accumulated info" tab? This doesn't sound familiar to me.
It's in the dashboard setting:
I know where it is displayed. How do I access it to reset it like you do?
Press and hold the "OK" button to reset it after each fill-up.
I’m not sure why this is so difficult but press and hold what to reset??? My dash is not touch screen and I’m certain yours isn’t either.
Do you have a picture of your steering wheel? There is an OK button on the steering wheel itself. It's right next to the scroller which you use to scroll through the functions. Press that OK button to reset.
I see the ok button. Thank you 😊
