VenomKia
Great write up. Question, the rear differential has a weird spec, GLSD1 All Temps, even AmSoil doesn’t have an equivalent. I do have the service page for the car but nothing like 75w-85 etc gear oil for an equivalent.
Thanks for posting that.For what its worth, Wrenching Ryan released 2 videos for these two items:
MrMCar - question for you - I watched the WrenchingRyan video on an oil change for a Telluride and he adds BG MOA on every Telluride oil change. The manual recommends no additives and searching on Google, some people think BG MOA is snake oil, others say it makes a real difference. What is your opinion and recommendation? Do you use an additive when you do an oil change? I use Mobil One Advanced and the OEM Kia Filter and have never used an oil additive in any car.One very important distinction that pro's know;
Remove the fill plugs FIRST. There have been times many a DiY will drain, then can't get the fill plug out for whatever reason. Whatcha gonna do, flip the car over to fill it?
I use HotShot Secret oil additives in my vehicles.MrMCar - question for you - I watched the WrenchingRyan video on an oil change for a Telluride and he adds BG MOA on every Telluride oil change. The manual recommends no additives and searching on Google, some people think BG MOA is snake oil, others say it makes a real difference. What is your opinion and recommendation? Do you use an additive when you do an oil change? I use Mobil One Advanced and the OEM Kia Filter and have never used an oil additive in any car.
A GREAT Question!MrMCar - question for you - I watched the WrenchingRyan video on an oil change for a Telluride and he adds BG MOA on every Telluride oil change. The manual recommends no additives and searching on Google, some people think BG MOA is snake oil, others say it makes a real difference. What is your opinion and recommendation? Do you use an additive when you do an oil change? I use Mobil One Advanced and the OEM Kia Filter and have never used an oil additive in any car.
You can use the L-M 2030 every oil change. Albeit, I think that's a bit much especially, if you're using Top Tier fuel?Thank you MrMCar! I'll hold off on the BG MOA until needed. I've been following your recommendation for LiquidMoly #2030 and using it every 5K in my Telluride and Lexus ES350 FSport. They are both running great. I'm still considering testing the BG MOA in the Lexus as it uses 0-20w synthetic oil and we have about 45K on it. That said, the Lexus has a great engine that is very problem free. I was also wondering if some dealerships are using the BG MOA on Tellurides to prevent the oil problems some have experienced on the higher mileage Tellurides.
