Water pooling in the front passenger side floorboard. AC drain line?
NAR50
I have a water leak that I assume is the AC drain line that is soaking the carpet in the front passenger floorboard.
I found the drain line behind the panel and under the carpet by the firewall. I used compressed air from underneath the car, I fished a wire into the tube towards the dash and down into the little black diverter (i guess that's what it is) and that seemed to work in the drive way, but after I took it for a drive, it started leaking again.
Any words of advice for an easy fix so I don't have to mess with the dealership?
Any ideas are Much appreciated!
I found water in my 2020 Telluride in the carpet in the front passenger floorboard. what needs to be done?
thanks
thanks
Determine the source of the leak.
A/C HVAC condensate drain?
Sunroof (if equipped) drain tube.
Windshield replaced or bad bodywork history?
Then form plan of attack. Poking fixes to most likely candidates or suppositions are a waste of time.
I took mine in to the service dept and they fixed it for free.
if you never use your moon roof will the line get plugged?? we never use a moonroof
