mallardlake
- Mar 19, 2020
Has anyone watched (listened to) the video yet? I need some feedback
The car has 11,000 miles on it, all original parts. Seems to only make the noise when shifting to reverse, but that could be because we back out of the garage, so maybe we are not aware of the noise when out of the garage and shifting to drive.Maybe snow melts and rusts the pads?
Could very well be indeed. Back in the day my shop installed all kinds of aftermarket (go fast stuff) brake pads. Many had a higher metallic composition than the factory brake pads.
Brake rotors are indeed similar to railroad tracks. They lightly surface rust when wet and put away. One or two applications of the brake pads and it's gone.
Some types of brake pads can INDEED temporarily stick to the brake disc as a result of oxidation.
The noise could be (??) the pad forcefully being pulled away from the inside surface of the disc.
Tell me; Genuine Kia pads & rotors, OEM or aftermarket?
Exactly the same with mine. I believe that it is surface rust from brake pad to rotor. I live near a fresh water lake and just overnight the build up of surface rust is ridiculous. CHEAP STEEL being used and cheap rotorsI don't have tension on the transmission. You can see the caliper stuck to the rotor when trying to back out of the garage, and then it releases with a clunk. Still trying to get a video of it. Thanks
I have had Audi, Acura, Porsche, BMW and many others. They all show rust on the rotors after I wash the car and it dries overnight. They are are rough when I first leave the garage the after washing and pressing the brake pedla the first time. So far my EPB seems to engage and release smoothly. The clunk being described by the OP seems to be an issue. Maybe the EPB is defective and needs to be replaced? A dealer visit with a drive along to show the tech what is going on is in order.Exactly the same with mine. I believe that it is surface rust from brake pad to rotor. I live near a fresh water lake and just overnight the build up of surface rust is ridiculous. CHEAP STEEL being used and cheap rotors
It's not cheap steel that promotes the rust. It's mostly about the ferrous content.Exactly the same with mine. I believe that it is surface rust from brake pad to rotor. I live near a fresh water lake and just overnight the build up of surface rust is ridiculous. CHEAP STEEL being used and cheap rotors
Most newer Toyota vehicles have automatic parking brake application like Kia-Hyundai.Yes, thanks for your suggestion to buy a toyota.
Why would you be in neutral, then shift to drive? The parking would disengage if your foot was on the brake.I especially love it when I shift to neutral, then drive, and parking brake doesn't disengage.
My foot is on the brake. It doesn't matter why, the software is faulty if it doesn't disengage the e-brake when it's sifted out of Park.Why would you be in neutral, then shift to drive? The parking would disengage if your foo
Mine does. When I shift into reverse or drive. What is the reasoning shifting into neutral?My foot is on the brake. It doesn't matter why, the software is faulty if it doesn't disengage the e-brake when it's sifted out of Park.
