If you could find that article etc.. That would be great thxI thought I read that the Telly and Palisade have factory auxiliary transmission cooling which is why they are rated to tow 5000lbs with/without the tow package????
I'm going to look. I definitely recall seeing that info somewhere.If you could find that article etc.. That would be great thx
Now "tow pkg" is that in reference to the self levelling rear suspension on the US- Prestige pkg and the CDN - SX limited ?I'm going to look. I definitely recall seeing that info somewhere.
I too would like to know if my new Telluride SX has a transmission cooler. Tell me where to look and I'll climb under it with a flashlight.
Looking closer at my SX there are two lines coming from what I believe is the transmission. One line goes to the top of the radiator and the other to the bottom of the radiator. Not sure the attached pic shows it very well. So it looks like the Telluride transmission does not have a separate transmission cooler. Whether it's any different than the Palisade "heavy duty" transmission cooler remains a mystery.
Ever get a response on this?We need to get the member here that has both a Telluride and a Palisade to take a look and see of the Palisade has the same setup. According to the marketing literature all Palisade come standard with a heavy duty tranny cooler. Can't imagine why the Telluride would be any different.
I'll send him a PM and see if he is willing to take a look.
We'll that sucks!! If those lines are from the transmission and goes into the radiator, then it's a similar configuration as the 4Runner I had.
They wouldn't rate it to tow 5k pounds if it didn't have some sort of transmission cooling. The only reason to get more is if you are regularly going up/down steep grades near the 5k limit. If so, you probably want a different car to be honest.
I'd like to hear about his topic as well since I'm considering purchasing an SX with tow package. I live in CA and would be hauling an Rpod trailer, fully loaded around 4,000 lbs. I'm ready to pull the trigger on the Telly but this topic is making me pause......I think that statement is "spot on"....the Telluride is a fantastic AWD family hauler, but I'm pretty sure there are other SUV's out there that are "ready made" for serious trailer hauling.
