Towing capacity
Tasha
I see that the Telluride can tow 5000 pounds. Does this include the vehicle contents or is it just the load attached to the hitch? Thanks.
Just the weight of the trailer. Maximum weight on the hitch itself is 351 lbs.
Can the tow package be ordered on all trim levels? When I built an EX on the KIA.com site the tow package was flagged unavailable.
I have the tow package on my EX. Not sure about availability on the LX and S though.
The tow option (hitch and 4-wire) can be added to LX and S. The tow package is the tow option with added self leveling rear shocks and that can be added added to EX and SX. However all have the same 351 lb tongue weight limitation.
Thanks. I really just want the tow package to install a rack to carry coolers and such. Not sure whether to order the tow package or just install an aftermarket one. Does anyone have a good picture of the factory tow package? Does the middle portion of the bottom of the rear bumper come off or is it mounted under it?
It comes off and there is a plastic housing that replaces it. If you don’t need the wiring you can get away with just the tow hitch and the cover. Kia 2020 Telluride Accessories Guide. Or if you wait a few more weeks there should be aftermarket options for cheaper that might hang below the bumper.
See attached
Sorry - pet peeve here - hitch racks typically don't come with lights -- for your safety, you should install run/brake/turn lights. Those things extend back from a vehicle a fair distance, are generally black, with no lights or reflectors and mounted low - just asking someone to run into it. Bike carriers generally block some or all of the vehicle's lights - so they should definitely have lights added. LED lights (or strips) are inexpensive and easy to mount...
OK - off my soap box on this one...
I think it’s a great idea. But not a legal requirement and I have not seen approved DOT lights built into the popular hitch mounted bike carriers.
Agreed - kinda the point...
Since not a requirement, they would be considered supplemental lights which don't require DOT approval. However, there are many DOT approved lights that could be mounted to the baskets or bike racks for safety and visibility.
Does anyone know the if the receiver on the tow package is a 2 inch receiver?
Just purchased a hitch mounted cargo carrier basket. Based on this discussion I decided to get some lights that connect to the 4 pin for added visibility. They aren’t DOT approved but I figure they can’t hurt and are better than nothing added.
Hi everyone, Newbie question here: I’m shopping around for either a roof rack storage solution or a hitch basket/storage solution. But I am wondering about how a hitch accessories affects the total GVWR of the Telluride.
Am I right to assume 100% of a hitch basket/storage accessory’s weight is counted toward GVWR? Unlike a trailer with wheels that only adds 7-10% to the total tongue weight.
Hope the question makes sense.
Your assumption is correct. The total weight of a hitch basket and its contents must be factored in to the GVWR. Also, the total cannot exceed the hitch weight rating, which for the Telluride is 500 pounds.
Good call. NCTelly - Do you mind sharing which hitch basket you got?
Decided to try the:
Mockins Hitch Mount Cargo Carrier
I bought from Amazon but I think Walmart and Ebay also sell this one. It’s rated for 500lbs but it weighs 52lbs, so I have about 440 to work with. Also will have a roof top turtle shell type cargo carrier (XCargo Sears 15cu ft) on factory crossbars to hold a couple suitcases and random objects.
Here’s a site I used during research. Buyer's Guide: The Best Hitch-Mounted Cargo Carriers - The Truth About Cars
I would have preferred aluminum over steel but I didn’t want to spend a ton. The Ultra Tow one on that site is only 37lbs and 22” deep instead of 20”. But it’s ~$80 more. I liked the fact that I should be able to open the hatch on the Telluride if need be on the Mockins and I can fold it up.
