Definitely too much air in tires.Hey all, I just got a new 2021 EX Wolf Gray Nightfall AWD. Car is absolutely gorgeous and is turning heads all over the NYC streets!
I do have some concerns though. I’m coming from a Durango RT with a hemi so I knew going in the Telluride is going to feel different and more polite. However right away I noticed that I feel a lot of feedback through the gas pedal and floorboard. My girl in the passenger seat says it feels smoother than the Durango so maybe it’s just the driver side. I also feel like the brake pedal is a little wobbly when you move your foot to it.
I’ve read a bit on this thread and my issue is constant, not just at 70ish mph, it honestly feels a bit smoother at higher speeds that driving around town. I just feel every single bump, unevenness, etc in the road through the pedal and it’s driving me nuts. Is that just how the Telluride drives? My tires are at 46 psi so I’m going to lower that and check. Thanks
Day One: Rode with the Service Manager - he stated he definitely feels the vibration on multiple road surfaces.
We spoke about the Palisade TSB and he said that is a good resource however this more than likely feels like tire issues. More vibrating during a cold start, etc. etc. He mentioned Driveshaft issues have an iconic buzz or humming sound - for those that have gotten driveshafts replaced can you advise on what he may be talking about?
He is going to Road Force balance all of the tires and figure out what's going on...
The scary part...I believe they gave me a 2020 Sportage as a loaner - has the same vibrations during a similar MPH window.....
I am be SPEAKING way too soon right now but this might just be how their vehicles drive...?
What are the chances that Kia just bought a Sh*tty batch of tires and they are the ones catching heat for it?Very possible. I think it’s important to note that some people are complaining of a “rumble” or “humming” at higher speeds and getting a vibration, which is described by many to be felt the most in the seat or thigh area. While others of us are curious about the vibration in the gas pedal, I have no vibration issues outside of the gas pedal. I brought this up in another thread and immediately was directed to this thread, which makes sense, but I was already well aware of this thread and I think the two issues most likely come from different sources. I’m no expert, just my two cents. I can say that I recently put some winter tires on and immediately after driving it home it seemed to feel better. But now, it feels the same to me and I would tend to agree, that typically the vibration in the pedal is worse after a cold start. It’s really more of a nuisance than anything. I don’t feel unsafe by any means but this thread with the driveshaft issues had me concerned it could be more. I already had the service manager drive it and said everything is normal and blamed the 20 inch rims for most of it but I’ve always had 20s on my suvs and have never felt that in the pedal. I’ll address it again at my oil change appointment but long story short...you may be completely right that this is how they drive. Problem is, I’d assume there would be a lot more complaints about road “feedback” in the pedal, I’m not sure how else to describe it. I’ll certainly be curious to see if anyone finds a solution.
That's what I originally thought...figuring maybe it was the Michelin tires. My winter tires are Conti Vikings...neither tire is a slouch and I know that typically you'd get a worse ride from a winter tire but I still have the same issue.What are the chances that Kia just bought a Sh*tty batch of tires and they are the ones catching heat for it?
the gas pedal shaking would annoy the crap out of me to be honest...not to say that my ass and thighs shaking is fun but my pedal and steering wheels are fine.That's what I originally thought...figuring maybe it was the Michelin tires. My winter tires are Conti Vikings...neither tire is a slouch and I know that typically you'd get a worse ride from a winter tire but I still have the same issue.
They had given me a Sportage but I did not feel the vibration. Probably because the road noise was distracting me. lolDay One: Rode with the Service Manager - he stated he definitely feels the vibration on multiple road surfaces.
Was Kia Teck Line there?As the story goes they road forced balanced the wheels. Will ask the techs for a detailed explanation of what they found. Meaning did they need to add any weights, any tires out of round...did they rotate them too?
I love how they are like it's ready for pick up without going in depth. Guess that's common for any service manager trying to get rid of you.
No they called Tech Line before working. That is the normal protocol for the Telluride. SM said they can't freaking drill 2 more holes for my rear license plate because they would have to get Tech Line back on the phone. Talk about Kia being "tight" on this vehicle.Was Kia Teck Line there?
I dropped mine off today at the Driveshaft Specialist shop and should know something tomorrow on it.
I think I told you they road forced mine and replaced my right front tire. That's the process they go through. I'm sorry to sound so gloomy but it sounds like a de Javue.
I hope it works out.No they called Tech Line before working. That is the normal protocol for the Telluride. SM said they can't freaking drill 2 more holes for my rear license plate because they would have to get Tech Line back on the phone. Talk about Kia being "tight" on this vehicle.
My SM was in his later years and highly experienced. He says when he talks to Tech Line they listen since he makes sense. He said the ultimate goal for him is to fix issues, period. Kia Tech Line normally doesn't get in his way because he pushes all of the facts.
Let's see.
Sending out a field rep to the Northeast would be nearly impossible.
Did they try telling you the road forced worked and you had to bring it back some time later and say look it's not gone?^ That's the best description for what I was feeling. It was not really audible, just something I could feel in the seat when it kicked in. Felt like switching from a freshly paved road to a slightly gravely one.
Yep. Based on my experience, every single warranty repair on the Telluride has to go through techline for instructions. Mine started with road force balance as well, then moved on to road tests with the driveshaft disconnected (confirming the issue was there), which then led to several rounds of parts replacements. My repair turned out to be exactly what the Palisade TSB called for, only it took two driveshafts and two couplers to get it right.
They are asking me to pick it back up tomorrow which I'm OK with as I'll give them the benefit of the doubt but if I still feel it I'm bringing it right back.
Nervous to hear what a driveshaft specialist tells @Bev tomorrow...
I think you had the best dealer anyone could have asked for with this issue to be honest. Glad it fixed it!No, the road force didn't fix anything so they held on to it, went back to techline, ordered parts, etc. They ended up holding on to it for 12 days (the first time).
Could it be your temporary paper plates flapping in the wind?I apologize in advance if this is a highjack....
My brand new 2021 EX Nightfall with AWD has a sort of "pulsing" going on in the rear end. It's not so much a vibration, although there might be a minimal amount. It's more of a sound, that increases with speed. It's not very loud, and the stereo and road noise drowns it out.
The low tire pressure light tripped with a recent cold snap (Florida). I added a little air but now that it's warmed back up outside, the pressure is high. I'll drop the pressure to see if it has any effect.
Any other ideas?
Thank you.Could it be your temporary paper plates flapping in the wind?
I had to nail down a weird/similar noise and found out it was my temp plates.
