gman1868
The name is... Dumas.
I live in Minnesota, where they use sand and rock salt on the roads every winter. Paint Protection Film is awesome! Our 2007 Escape still does not have any chips in the paint where we installed it. With the big flat front on the Telluride, it will be well worth the investment. I'll be having it installed right after the car is delivered by a local installer. When you look for your installer, some will have the equipment to cut the pieces on a table using a computer controlled cutting table so they don't cut the film on the car. That is preferred.
As far as protecting the rest of the paint, you can use carnauba wax, paint sealants, or ceramic coating. With hand washing, wax lasts about a month or so, paint sealants about 6 months or so, ceramic coating, a year to 18 months. Many factors influence the duration such as climate, temperature, sun exposure, road crud, etc. Your results may vary
If you're so inclined to do it yourself, ceramic coating with high quality products like those from Griots Garage, you can do this relatively inexpensively. On a new car, you can wash it and put on the ceramic coating in an afternoon (out of the sun, of course). Using ceramic, it means I can coat the car once a year in the Spring or Fall when it's not too hot or too cold and I don't have to worry about anything except washing and removing things bird poop or equally bad crud from the car as soon as I see it.
If you decide go down the rabbit hole of detailing like I have
there are other things you can do over the life of the vehicle to keep the paint in excellent condition. Clay bar to clean, polish, to remove surface scratched in the clear coat, then use the ceramic coating to seal it again. Or, you can take it to a local shop and they can do it for you
You can carry a spray war wash bottle in the car so when you get that inevitable bird bomb on the car you can wipe if off immediately to prevent it from damaging the paint. If you decide to join us in the Wonderland of car detailing, the options are many and the time is well spent.
