Folding Mirrors
Can you tell me exactly where that is in settings?
Press the menu button on the steering wheel controls repeatedly until the USER SETTINGS menu is displayed on the dash between the dash gauges..... Then follow the directions posted previously by "chaidart".
Like you...I had a heck of a time finding it. I was looking for it amoungst the menus on the infotainment screens.
Thanks for the info on User Setting; what I was doing to eliminate the mirrors always folding: When exiting the vehicle with drivers door open, press the door lock button on the drivers door, close door and walk away. Every now and then it would sense my key fob in pocket and immediately unlock but not all times or just re hit lock.
I believe the side mirror adjustment, where you switch between the left and right side mirror does have a purpose. If you do not leave it in the center, when you reverse the side mirrors will tilt down. Putting the switch back in the center disables the tilt down on reverse.
THANK YOU!!! That worked!!!
Does anyone know if there is a setting to stop the mirrors from folding in when parking the car?
There is a button above the side view mirror controls that depicts the side mirror with an arrow. Press that and it will adjust the settings.
Guest user chiming in over a year late to provide the wrong answer to a question that was already solved by the OP in post #7. 👎
