Karam.31
Same issue here.... anyone get this successfully fixed on an SX? Assume it is an easy dealer fix, just need to take it in I guess.
Mine leaks a while before it stops. After each use. So the issue they are having makes sense. Hopefully they will have a fix soon.Same issue here.... anyone get this successfully fixed on an SX? Assume it is an easy dealer fix, just need to take it in I guess.
Yeah I'm certainly not hitting the lever. It leaks when the car is off too. I'll leave and come back hours later and see the streaks.My wife was saying the same thing about our new SX. She even showed me the proof of trail on the glass. Turns out she was accidentally hitting the lever causing it to turn on ever so slightly. Hasn't happened since she figured that out.
I'm experiencing the same issue. My guess is that the fluid that remains in the feeder hose gets pulled out by the low pressure created under the rear spoiler while driving. Essentially, the vehicle is siphoning its own washer fluid. Just my guess. I'm going to give it a few weeks to sole itself as you did. Fingers crossed!After 6 weeks of ownership my leaking rear washer nozzle seemed to repair itself. Could be a seal that eventually seats. Dunno. But, also logged it with the svc mgr to be on the record with this issue. Enjoy the ride.
Hey fellow Telluride owners
Not sure where to post this but, I will put it here.
Is anyone having trouble with their rear windshield wiper fluid nozzle continuously leaking?
Mine is and Kia is telling the techs it’s normal? I dunno about that because it is constant. Anyone else having the same or heard of this issue?
The only fix I believe will be to move what I assume is a small check valve closer to the nozzle. Kia seems to have screwed up and fit it somewhere too far upstream. Surprised this isn't one of those things that is caught with early test mules. Such a silly error to make it to production.Me too! I don’t see anybody mentioned a fix yet. I used my rear washer 2 days ago for the first time. It’s still leaking. I will check with dealer later SXP....
My leak eventually stopped. It hasn’t leaked since. To my knowledge the dealers or Kia gave no resolution to the issue.
What I did hear was that the small seal that keeps it from leaking ( back flow ) needed to seat itself after a few uses. Just what I heard. If yours is still doing it I would press the dealer.
