Leaking rear windshield nozzle
Saw an older thread on the topic here as well. I will follow here too to see if a fix is found.
But, as others have stated and with talking to the advisor, it’s a known issue and the issue is the water line between the nozzle and the check valve is filled with water after use. The water then leaks/drips until that portion of the line empties.
Minor =yes
Annoying =yesx2
A Technical Service Bulletin has been posted - click here
Applies to build dates April 1, 2019 through October 28, 2019
Thanks for the update.
Will be scheduling service for mine. Tired of cleaning the window all the time.
So is this a situation where you run fluid and when it stops, the residual fluid between the valve and the exit continues to slowly drip until it is depleted and then the drip stops?
that is exactly what the technician told me at the dealership he called it (bad design)
