TellurideSX
- Apr 8, 2019
I drove both prior to purchasing the SX and the EX rides better in my opinion.
Thanks...now I get it...appreciate the tutorialTaller sidewalls not only means that they will absorb potholes better, but they also ride much smoother on rough roads.
That's why all the offroaders you see have large meaty tires with lots and lots of sidewall for cushioning purposes.
Thanks...now I get it...appreciate the tutorial![]()
It's pretty flashy too! Which is a good thingDon't think that I'm hating on 20" wheel because I'm not. 20" rims look fantastic.
But, 18" are more practical and this vehicle is all about practicality and not flashy.
Why not just put on the seatbeltsMy in-laws will sit there and let the chime ring for 40+ times on their X5. I don't know how they stand it. Always yell at them to just buckle up.
Apparently America needs MORE HD radio channels, or They need to get the weather from a different source. Wish android auto would do that.Anyone else have an issue with the weather app thing in the dash? Mine just refuses to resolve...constantly just “loading”...
Super annoying. Even my dealer has no idea
You’re essentially riding on more air and the sidewall provides for shock absorption. Bigger rims require the sidewall on the tire to be smaller but also harder to compensate.I know this may be naive...but meaning those will absorb potholes better?
That’s kinda like saying you once fell down a flight of stairs while naked and then refusing to ever be nude again and taking showers in a pair of cut off jeans....He feels uncomfortable. She believes she would have been dead many years ago if she had her seat belt on when her car got t-boned- she was thrown to the other side and didn't get crushed. Some crazy belief she has dating back many years.
- Adaptive Cruise Control doesn't always pick up traffic stopped at a light. I've been testing the cruise control and sensor functions trying to figure out where/when certain things engage and the one that I've found surprising is that I can come up to a red light with cars stopped ahead but the car seems to want to plow on through. I'm talking 20-40mph so I obviously leave enough room to brake on my own, but I worry that the algorithm either isn't there or is not conservative enough. Not plannig on going so far as checking the emergency braking feature so I'm hoping I'm just more conservative than the algorithm is.
I am glad that you are experimenting with the Adaptive or Smart Cruise Control(SCC). In the settings for the SCC there are three options to chose from which determine how quick you want the system to react. It's been about 3.5 months since I set my SCC however I am relatively certain chosing the "faster" option, which sounds counter intuitive but the "auto breaking" begins sooner so you don't get that "is it ever going to slow down felling" when approaching an intersection with a car in front of you. I think if you try the three SCC options along with the "car lengths" button on the steering wheel you will find the right combo that will make using the SCC much more relaxing.
I do have the AWD SX with Prestige Package, however I believe the SCC options are the same on all the models but wanted to clarify in case there not.
- Smart Lift Gate opening criteria. I get out of the car, get the baby out of the back seat, then occasionally have bags to get out of the rear. Would be nice to have the lift gate operational criteria adjusted for this, instead of just returning to the vehicle after a shopping trip or something. I know I can just open the hatch before getting out or press the button on the back once I get there, but it would be nice to have the feature work when you're there.
Your going to find that most systems with adaptive cruise control behave this way and more so the faster your going. They are actually programmed to ignore their sensors in situations like these because you don't want false positives leading to cars slamming on their brakes, especially on the highway. A common cause of these false positives are overpasses. If the car is not already tracking a car while approaching a red light I would never expect it to stop.
Yes, I found that feature, but am looking for a way to make it permanent. It appears I'm not the only one. Maybe a future software update will provide that functionality. Hoping for the same with the cruise control. I use it frequently enough, I'd like it to remember the last position it was in versus turning it on every start up.Idle stop and go can be turned off by pressing the button near the shifter / AWD knob. The button has an A on it with a circle around it. Needs to be turned off every time you start the car tho.
I don't understand this....Are you saying that the Smart Lift Proximity Sensor is not working? That's when you stand behind the rear hatch for a couple of seconds the lift gate automatically opens. I believe this feature is disabled by default. You have to enable it.
I've enabled it. Kia programmed specific criteria that prevent it from opening though. So, if I get my kid out of the back, close the door, by the time I get to the rear, its been maybe 3 seconds so the liftgate criteria haven't been met. If my other kids are still getting out on the other side, criteria also hasn't been met because their door is still open. The intent of the smart liftgate implying the use to only be the driver returning from shopping with hands full and going to the liftgate before anywhere else. Just a quirk I'm sure is part of any other manufacturers mart liftgate. From the owners manual:
Using the smart power liftgate
The liftgate can be opened with no-touch activation when all of the below conditions have been satisfied.
-- 15 seconds have passed after all doors have been closed and locked.
-- The smart key is positioned within the detecting area for more than 3 seconds.
NOTICE
䳜The Smart Power Liftgate does not operate when:
-- The smart key is detected within 15 seconds after the doors are closed and locked, and is continuously detected.
-- The smart key is detected within 15 seconds after the doors are closed and locked, and within 60 in (1.5 m) from the front door handles. (for vehicles equipped with Welcome Light)
-- A door is not locked or closed.
-- The smart key is in the vehicle.
