- Mar 7, 2019
ETA showing 10-15 as of today@StephenCantrelle Will you please give me an update on VIN 5XYP5DHCXNG224495. I have a deposit on the vehicle. Thanks!
Thank you!ETA showing 10-15 as of today
Awesome thanks so much!Showing In Transit to dealer with ETA of 10-01 as of today
JONA name is attached.. what is your initials?
Hi do know what could have happened if they had in transit on Aug 25th and then a week later showed it pushed back to Oct?Awesome thanks so much!
Showing In Transit to dealer with ETA of 09-24 as of todayWould you check vin 5xyp5dhc6ng219598? Thank you soo much!!
Showing different name on this one.. if you did a custom order this is not the one.. if you put a deposit on one already assigned to dealer than ETA is showing 11-05 as of today
looks like got delayed a week.. it happens.. likely due to being on a rail then truck transport to ColoradoHi do know what could have happened if they had in transit on Aug 25th and then a week later showed it pushed back to Oct?
Showing In Transit to dealer with ETA of 09-24 as of today@StephenCantrelle , was wondering if you can check ETA on 5XYP3DHC2NG220124. Thanks a lot for the help
Hmm not sure what the difference is we just placed a deposit and told them what we wanted. Looked that up on failcat and seemed to match exactly. Well thanks for all your help!Showing different name on this one.. if you did a custom order this is not the one.. if you put a deposit on one already assigned to dealer than ETA is showing 11-05 as of today
Placed a deposit and told them what we wanted. Found an exact match on failcat. Not sure what the difference between custom or assigned is. Anyways I appreciate your helpShowing different name on this one.. if you did a custom order this is not the one.. if you put a deposit on one already assigned to dealer than ETA is showing 11-05 as of today
@StephenCantrelle again pleaseHey @StephenCantrelle can you check 5XYP5DHC9NG222110 again for me. Hoping for the date to have moved up some
Thanks Stephen!Showing in transit to dealer with ETA of 10-06 as of today
Custom order and build vs one already coming to dealership and already had an ETA to arrive and you put a deposit on it.Placed a deposit and told them what we wanted. Found an exact match on failcat. Not sure what the difference between custom or assigned is. Anyways I appreciate your help
Seeing different name on this one which is normal if you put a deposit on one already assigned to dealer. If you did a custom order than this is not the one.. ETA showing 10-12 as of todayHey @StephenCantrelle i was wondering if you could check ETA and track VIN number 5XYP3DHC1NG225671 for me. Initials are SB or IB. Thank you!
ETA showing 09-26 as of today@StephenCantrelle again please
