hey @StephenCantrelle - new to the forum. looks like you have special insights to the factory builds.
can you check S9W7J6A1KHH00X
Is it common for it to say in stock and it not be?Check with dealer.. showing in dealer stock!
Showing in transit with ETA of 09-25 as of today.. have been seeing delays lately but looks like you are close for it arriving@StephenCantrelle if the truck is delayed is there a way to get an ETA? Dealer is saying it didn’t show up on 9-20 so trying to find out when it will arrive now. The VIN again is 5XYP5DHC4NG219180
It does happen every now and then.. usually when this happens it shows in next day or twoIs it common for it to say in stock and it not be?
Thank you so much!! Stay hydrated~$ coming to ya!TA is attached.. ETA showing 09-29 as of today
Hey @StephenCantrelle if you have a minute could you peek and make sure I’m not about to get bumped again! Thank youETA showing 09-27 as of today... cash info is in my signature below.. Thank you!!
Just a weekly check to see if we're still set for 9/29, hoping I don't have to change my flight. VIN is 5XYP6DHCXNG219195, not custom order, just caught of allocation so won't have my initials attachedShowing In Transit to dealer with ETA of 09-29 as of today.. so holding ETA as of now
Dealer has marked sold so can no longer track.. check with dealer on this Vin as I see sold under different nameHi @StephenCantrelle !
New member here! When you have a moment would you mind to check VIN: 5XYP6DHC6NG217590 initials would be RL?
Thank you in advance!
Not showing up on my end at all. Need to check with dealer..Hey @StephenCantrelle if you have a minute could you peek and make sure I’m not about to get bumped again! Thank you
Check with dealer. Dealer has marked sold internally so can no longer trackJust a weekly check to see if we're still set for 9/29, hoping I don't have to change my flight. VIN is 5XYP6DHCXNG219195, not custom order, just caught of allocation so won't have my initials attached
Showing In Transit to dealer with ETA of 10-08 as of today@StephenCantrelle would you mind checking 5XYP5DHC1NG222022 one more time please? Thank you![]()
ETA showing 10-04 as of today..Hi @StephenCantrelle could you check 5XYP5DHC3NG217257 again? Thank you for your time.
Yes that is correct. Could it be on the road or at the dealer?Not showing up on my end at all. Need to check with dealer..
5XYP5DHC8NG217951. Please verify this is correct full VIN
Yes that is correct. Could it be on the road or at the dealer? 5XYP5DHC8NG217951
Don't know what happen but it is no longer showing at all on my side.. will need to check with dealer directly on this oneYes that is correct. Could it be on the road or at the dealer?
Showing In Transit to dealer with ETA of 10-05 as of today..Hey @StephenCantrelle, thanks again for this service (tip sent for bugging you more than once!). Checking on 5XYP5DHC1NG220870, initials SB.
Thanks!!
