Alonzo_Tigerhart
IG: @TellyRidin
- Mar 17, 2019
I wouldn’t call it a rub it’s more of a graze with the Ridge Grappler that is generally a bigger tire. If I went Terra Grappler I might not be “grazing” as much.Beast, any rub? May run this size
Looks good!I have the Toyo AT 3 265/65/17 XD monster rims and I’m getting just a slight rub or graze like Alonzo mentioned. When I’m full turn it’s very mineable but I think I might try the heat gun on the fender. Good idea Alonzo![]()
Yellow fogs look nice. What model are those?View attachment 15864View attachment 15865View attachment 15866
Raceline Scout 18x8 +35
Nitto Ridge Grapplers 265/65/r18
Truxxx Lift Kit
The fogs? I just had yellow vinyl wrap put on them. I don’t think there are any aftermarket ones out there.Yellow fogs look nice. What model are those?
What mounting brackets did you use to attach your platform? I was going to use the cross bars I have but I think it will make the platform appear weird with their height.View attachment 15864View attachment 15865View attachment 15866
Truxxx Lift Kit
They are the ones for the Kia Sedona and then slightly modified. However FrontRunner is working on something more official for the Telluride right now. I’d wait for that.What mounting brackets did you use to attach your platform? I was going to use the cross bars I have but I think it will make the platform appear weird with their height.
Ordered my lift kit. The Truxxx instructions that was posted here mentioned something about the rear install with the self-leveling suspension. Probably something to bring up with your mechanic.Yea I noticed the same. Most people with the Tow package seem to sit lower in the rear when parked. Supposedly driving the car would automatically level it out, but I don't know if that actually happens.
were you off road when it broke? Do you know what the cause was?DO NOT USE THE TRUXX SWAY BAR EXTENSIONS! Both bent on me and passenger side sway bar bent. Caused the axle to be damaged and pop out. Kia service told me the extensions are not needed. If you have more questions, I'm happy to answer.
We did a little off roading the weekend before, but at the time I was towing a 4000 lbs trailer. We had already been towing about 6 hours before I started to feel the Telly shake when I applied gas. So not sure what caused the bend in the Sway or bends in both extensions.were you off road when it broke? Do you know what the cause was?
That's exactly how I installed those link plates, Thanks for the pic!, I can tell that accessing the front sway bar brackets is not as easy as the rear ones but TRUXXX recommends to get them loose, drive the vehicle around and tight them back in their new position, I also added the factory skid plate, this is mine with 245/70/17 wheels/tires.My installer had to come to my home after he got off work to fix an issue. It started making a tug tug noise from the front of the car while driving.
Apparently he missed critical step #9.
To readjust the front sway bars.
Here with Toyo AT 265/50/20.
