Finally got around to replacing the incandescent bulb with a yellow LED bulb on my EX. Now it crisply blinks like a proper LED light bulb should, instead of pulsing on and off. I like it!
You have to use a CANBUS 1157 bulb, otherwise you will get an error. I also had to fashion a "tool" to get the socket loosened. Otherwise, it was impossible to turn the socket due to the tight space.
The only remaining incandescent bulb left is the back up light. Looking at it closer I don't know if removing the back panel will expose the light module. It almost look like I have a do something with a tab looking thing and then maybe it'll slide out. Wish I had a service manual! Anyone replace their backup light with LED?
