How to fix the emblems on a 2022 Nightfall
isn't that part removable? so you can just remove, paint(plastidip) and then re-attach?
I guess anything is removable but I think that the emblems are held on with double sided tape. If you discover otherwise please let me know. I’ve looked for parts diagrams online for 2022 model but can’t find one. Parts diagram would shed some light as to how they are held on. Previous models appear to use double sided tape so I can only assume that these do as well. Let me know if you discover otherwise.
Deja vu!!
I feel like I've already seen this before in other threads. None the less still way better looking than stock. 👍
Nicely done! They should have done it that way from the factory.
If the emblem is 3M double sided trim tape, you can take it off without damaging anything. The secret is to use dental floss. It will slice right through the tape and will not damage the paint.
Forgot to ask.... Anybody tried the black emblems that the forum sells on the 22?
Mines coming in July, and there has to be a solution to those nasty 'new Kia' emblems. Blacking them out is good. Wondering if these would look better??
Well I do like those emblems. i think it would work well on the rear as I believe they are held on with double sided tape. The front grill is another story as the grill is sculpted around where the Kia emblem is so it wouldn’t technically fit as good as it should. It way still work but I don’t think it would fit as well as you would want it to look on a $50,000 car
Yes, good point on the front grille. The pre-22 grille didn't have that problem. Back to the Hyperdip idea.
I’ll do the front as well and post a video of that.
Wow......awesome! thanks!
Yeah, I am wondering the same thing. For the back, I like the black emblems you liked to with the K. For the front, it is looking like hyperdip/plastidip may be the way to go. But it would be interesting to see a 2022 that switched both out.
So you guys can see the front emblem, wait no more here it is. Wonder why Kia didn’t do this from the factory. If this doesn’t hold up I’ll either gunkote or cerakote the emblems. Please let me know hat you guys think of the emblems.
Cerakote the KИ?
Great idea.
It should last longer than powder coat or plastidip at least, and now they have air-cured versions that don't require heat/ovens to cure.
I have a all blacked out nightfall edition. But all emblems are black except the one in front. What color plasti dip did you use? I'm going to do the exact same
So your rear emblem came blacked out from the factory?
No, but that one was removed and very easily. I did the black plasti dip on the front. But I've done it twice and both times I let it dry and when I peel the tape no matter how well it's taped it pulls in small places and messes up.
What product /finish did you use? Does it match the finish of the factory black emblems?
How did you remove the rear one? Are there any pins/clips/holes underneath the badge on the '22 or is it just taped/glued? Hoping I can remove it instead of blacking it out.
Thanks!
Thanks!
No. I applied heat with a blow-dry for a few moments ans pulled it right off they are so thin and flexible.
