Our sales rep. set our telluride up for smart mode before i understood comfort mode was the default mode. Is one setting preferred over the other and if so, why?
Thanks in advance for the help!
Smart mode adjusts between Eco, Comfort and Sport depending on your driving.Our sales rep. set our telluride up for smart mode before i understood comfort mode was the default mode. Is one setting preferred over the other and if so, why?
i’ve never used the other settings, i’ll have to try this next timeI noticed the smart setting changes colors based on my driving. I.e. if I accelerate hard, it turns red. I've also noticed times where it completely good off
Sport Mode in the Telluride is not racetrack aggressive. I think it's tuned pretty well for what the vehicle is. Shift points obviously get delayed. Once I plateau at desired speed, the transmission finds a gear in the neighborhood of 2200-2500 RPM -- where torque is readily available but not anywhere near engine braking.Does sport mode still upshift to proper gear immediately once you get to speed and maintain throttle, or it keeps holding low gear for awhile? I ask because my current car’s sport mode is useless, unless maybe you are racing on track. It’s too aggressive, holding on to the lower gear, keeping the high rpm way too long even after I back off the throttle. On normal mode, huge delay before you feel any response from the engine. The only way to avoid this is to drive the car aggressively so it keep the memory for the next time. But with a few slow starts from the light it goes right back to the delay. My experience, many Japanese cars do this and I hope Kia is not doing the same. I am not talking about slow acceleration from a stop, it’s the non responsiveness from the engine when you try to accelerate from slow speed, like after a turn, etc…
Anticipate your passes? How exactly?Okay, I tried smart mode, and it ain't smart enough. Until it can read my mind and anticipate my passes, it's not getting touched again.
Back to comfort and sport. Will report back on snow in 5-6 months.
Well its downfall is, when I want performance, it can't give it to me on time. There is a difference punching it when its in smart mode vs sport mode. Sport mode jumps out, the other one just sits there for a second trying to figure out what it should be doing. Comfort and Sport are right next to each other, so minimizing it to two reduces distraction along with improving my experience.Anticipate your passes? How exactly?
Here is what works for me when I pass.
#1 if I find my speed is not fast enough, press down on the accelerator harder.
#2 if the accelerator is floored, it won't go any further regardless of whether I have sport, eco, or smart.
So it's quicker for you to switch from comfort to sport and then punch it rather than just punching it? This would be interesting to measure.Well its downfall is, when I want performance, it can't give it to me on time. There is a difference punching it when its in smart mode vs sport mode. Sport mode jumps out, the other one just sits there for a second trying to figure out what it should be doing. Comfort and Sport are right next to each other, so minimizing it to two reduces distraction along with improving my experience.
i know where i can pass around where i live and switch in anticipation. the car doesn’t.So it's quicker for you to switch from comfort to sport and then punch it rather than just punching it? This would be interesting to measure.
Sounds like your car is yet to arrive?
