Wonder if there are plans to upgrade the technology in the Telluride like the 2021 Sorento that has wireless Apple Play/Android Auto?
Agreed on 1-3, we’ve found this all to be true. Re: #3, their UI is awful.Agree that the wireless Carlink add-on is a great addition for Apple CarPlay. For those who share your Telly ride with your significant other be aware of these caveats:
- Wireless Carlink selects the last user when two iPhones are present at the same time.
- You are able to switch users when you start your vehicle by selecting your Apple device from the Telly touchscreen; however, you will have to select your device two or three times during the initialization process because it may try to go back to the last user.
- The startup GUI interface is generated from the Carlink accessory so it's not the most intuitive.
- Once your wireless device is connected and you hit the road you will not be able to switch CarPlay users on the fly, you are stuck with the CarPlay user selected during startup unless you do this: unplug and reinsert the wireless Carlink adapter to restart the initialization process while on the road. That way (suggest the passenger do this) you can select the other user.
If you’re trying to change the device connected to the adapter on the fly, the quickest way to do it would be to toggle WiFi on and off on the device currently connected to the adapter. That will kill its connection and prompt the adapter to search for a device to connect again. Then, you could just choose the other phone you wanted.Once your wireless device is connected and you hit the road you will not be able to switch CarPlay users on the fly, you are stuck with the CarPlay user selected during startup unless you do this: unplug and reinsert the wireless Carlink adapter to restart the initialization process while on the road. That way (suggest the passenger do this) you can select the other user.
Amazon prime. You can get it in 1-2 days.Thanks for this! Looks great. I have one on order, but my order number is like 27,000 and it seems like they've been struggling to get production up to peak. I probably have a couple more months to go.
AA Wireless is only available via the Indiegogo campaign. It is not on Amazon, nor are there any other adapters to enable wireless Android Auto currently available.Amazon prime. You can get it in 1-2 days.
Didn’t realize we had shifted this discussion to strictly Android. My bad.AA Wireless is only available via the Indiegogo campaign. It is not on Amazon, nor are there any other adapters to enable wireless Android Auto currently available.
It’s not strictly Android in this thread, but the post you were replying to was someone who was thanking someone else for showing info about AA wireless. Just wanted to make it clear that they couldn’t get that from Amazon. Not that easy for those on Android, unfortunately.Didn’t realize we had shifted this discussion to strictly Android. My bad.
But does that disable the wireless charging pad in the SX model? So if you need to charge you need to plug in anyways? Before I buy I’d like to be sure.As far as I’m aware the 10.25” unit was pretty much brand new for the 2020 model year and isn’t due for an update yet. The 8” unit had been out for a bit and is being updated for 2021 for many models (albeit not the Telluride). Unfortunately at this time that means you get the weirdness of a nice feature not being available on the premium unit because we’re at a transition point.
The good news is this problem can be pretty much solved with a ~$130 adapter like CarPlay2Air.
Wireless charging and wireless Apple carplay are two separate technologies that have nothing to do with each other.But does that disable the wireless charging pad in the SX model? So if you need to charge you need to plug in anyways? Before I buy I’d like to be sure.
No it does not disable the wireless charging pad.But does that disable the wireless charging pad in the SX model? So if you need to charge you need to plug in anyways? Before I buy I’d like to be sure.
Correct on the last comment, plus note that wireless charging will be automatically turned off by the phone if it gets too hot (from excessive use as mentioned above). This has happened to me on long drives.Wireless charging and wireless Apple carplay are two separate technologies that have nothing to do with each other.
Wireless Carplay is just transmitting data from your phone to a receiver connected to the USB data port in the car. Regardless if plugged into another charger or wireless charger it will work the same.
The wireless charging pad in the car will work, so long as you don’t have the lightning cable plugged into your phone already (ie. while using wireless Carplay). Be aware though that if you are heavily using your phone with navigation, music, etc., it is a good chance the phone battery will still drain faster than wireless charging can chargr. That is just a limitation of wireless charging efficiency though in general.
Just like every single 10.25”+ Hyundai/Kia infotainment system with navigation. None of them have wireless CarPlay/AA. The only systems that have wireless CarPlay/AA are the 8” units on certain 2021 or newer Hyundai/Kia models. This isn’t new or surprising at this point.So we just picked up a 2022 Hyundai Tucson Limited model for my wife. I saw that the new Tucson advertised wireless CarPlay and was excited to get it. Turns out the top of the line model with the 10.25" screen doesn't have wireless CarPlay, only the lower models with the 8" screens have wireless CarPlay. What kind of stupidity is that??? I wonder if the internal guts for the 10" screen are the same as our Tellie's and that's why there is no wireless option?
I'm not unhappy by any means.. Just surprised that moving into a 2022 Tucson which is a brand new design, that they didn't bother to add it. Unfortunately the detailed specs weren't out yet when the vehicle was ordered, only basic specs. They just recently added the car to their website with all information. I added Carlinkit 2 to my Telly and have just ordered another one for her car. No biggie, carlinkit works great.Just like every single 10.25”+ Hyundai/Kia infotainment system with navigation. None of them have wireless CarPlay/AA. The only systems that have wireless CarPlay/AA are the 8” units on certain 2021 or newer Hyundai/Kia models. This isn’t new or surprising at this point.
I almost wish they had just held off on adding wireless CarPlay support on the 8” units until they had some bigger units that supported it as well. Because this has led to so much confusion from people who don’t read the spec sheets and make assumptions, dealers who don’t know anything and tell people the wrong thing, etc… and ultimately, you wind up with disgruntled owners. The Palisade forums/FB pages are littered with misinformed people who just assumed they were getting wireless CarPlay when they bought their top-end Calligraphy because they read or heard low-end models had it. Nope, sorry.
Seriously, though, very few other missing “must have” features can be acceptably remedied with the $150 or less adapter. And take solace in the fact that the factory wireless CarPlay setup has had some teething problems… people have reported incessant disconnecting, sometimes even after a software update to fix the issue.
