Key Fob
Jessica713
Ok, so this is kind of strange. i drive home today and whe. I tried to lock my 2021 telluride Sx, it wouldn’t lock from the outside. My key fob will lock the doors from the inside, but it will not work from the outside - anyone else have this issue?
Only when another fob is in the car.
Happened to me but only when I was in the back, right behind the gate, couldn’t do anything with the key fob. I couldn’t open the gate manually either. Seemed like the car didn’t recognize it. I had to walk closer to the driver’s door for it to work normally. It was back to normal the next day.
Watch out that you don’t have things blocking/interfering with your fob. That could have been your problem if the fob was buried in a purse or bag under a phone, or even wedged between other interfering devices in your pocket.
