Do you have the factory tow package?Just wanted to update. Brought car to dealership after tires and lift kit installed and they fixed my alignment problem. 265/50/20 tires work great.
What kind of tires and size and rims are they?
NoDo you have the factory tow package?
stock 20 inch wheels with 265/50/20 Yokahma geolander all terrain geo15. Works great, no rubWhat kind of tires and size and rims are they?
Wow that does look really good.Figured I’d show a few pics of mine. We just picked up the car on Saturday.
I installed the Truxxx lift last night and put the new wheels/tires on. Still need to get an alignment but they’re scheduled way out there right now.
Tires are Cooper Rugged Trek, 265-60-18’s. Wheels are Niche Vosso’s. Love the wheel tire combo.
There is still a bit of rubbing. May need to pull the wheel liner and grind down some sheet metal. We’ll see how that goes.
This thing looks amazing now.
Yes we do.Wow that does look really good.
I have this same color 2022 EX night fall prestige with tow but with 20” rims and I’m looking to put 265/50R20 all terrain on it with the same lift hopefully no rubbing. Also swapping Axel back part of exhaust for better soundFigured I’d show a few pics of mine. We just picked up the car on Saturday.
I have a 2020 SX AWD that has been in the shop for 4 days, as the Truxxx lift has caused the rear shocks to be maxed out. When driving the vehicle around the block there is an irritating clunking noise. The shop has followed the directions to a T on 2 separate occasions. They've contacted Truxxx for advice multiple times (and even spoke with the owner), contacted Kia, and had outside technicians look at the issue. Nothing has helped. If anyone has advice it would be greatly appreciated.
Re-check/ tighten rear sway bar end links. If one is slightly loose it'll clunk.I have a 2020 SX AWD that has been in the shop for 4 days, as the Truxxx lift has caused the rear shocks to be maxed out. When driving the vehicle around the block there is an irritating clunking noise. The shop has followed the directions to a T on 2 separate occasions. They've contacted Truxxx for advice multiple times (and even spoke with the owner), contacted Kia, and had outside technicians look at the issue. Nothing has helped. If anyone has advice it would be greatly appreciated.
Love the way the smaller wheel looks with the bigger tire, I am running about the same tire diameter but with the stock 20's. Thinking about going to a smaller wheel. Did you sell your 20's? If so what where people willing to pay? Also is there anything you would change about your set up?View attachment 15864View attachment 15865View attachment 15866
Raceline Scout 18x8 +35
Nitto Ridge Grapplers 265/65/r18
Truxxx Lift Kit
Is the clunking coming from the front or rear? Totally different applications and require different trouble shooting approaches. If you can give a little more info that would help with suggestions. I have fixed a number of different problems on these lifts but each solution is specific to where the issue is originating.I have a 2020 SX AWD that has been in the shop for 4 days, as the Truxxx lift has caused the rear shocks to be maxed out. When driving the vehicle around the block there is an irritating clunking noise. The shop has followed the directions to a T on 2 separate occasions. They've contacted Truxxx for advice multiple times (and even spoke with the owner), contacted Kia, and had outside technicians look at the issue. Nothing has helped. If anyone has advice it would be greatly appreciated.
Did you keep your OEM 18” wheels? Any pictures? I’m looking to stay with my OEM 18” LX wheels with the exact tires you are going with.I'm going with Nitto Ridge Grappler 265/60 18". I'm staying with 18" but bigger wider tire to get good traction off-road camping and I like the silver rims.
What offset are the 18 wheels?Figured I’d show a few pics of mine. We just picked up the car on Saturday.
I think this is happening to mine right now they want me to remove back to factory how did you fix so the lift could stay?DO NOT USE THE TRUXX SWAY BAR EXTENSIONS! Both bent on me and passenger side sway bar bent. Caused the axle to be damaged and pop out. Kia service told me the extensions are not needed. If you have more questions, I'm happy to answer.
Just remove the extensions, no need to do anything else.I think this is happening to mine right now they want me to remove back to factory how did you fix so the lift could stay?
