Yes, there is no folder, just the fikesAre your files in the top level directory and not in a separate folder?
Try downloading the update directly to the flash drive instead of the computer.Yes, there is no folder, just the fikes
Have you tried formatting the USB stick to FAT32? Also, make sure the files are not inside a folder on the stick. All ~20 data files need to be in the root directory of the drive.Still Can't get my car to recognize the files on the USB stick. I downloaded directly to the stick, it just wont work. Doing this via a mac if that matters in terms of formatting.
Thank you for your helpAll the directions are at update.kia.com.
You can go to setup > general > SW info/update and find your map version.
14.0 (Apr 2020) NAM.13.41.42.660.202
14.5 (Aug 2020) NAM.13.47.44.680.201
14.10 (Nov 2020) NAM.13.47.50.610.201
15.0 (Apr 2021) NAM.14.41.43.490.301
15.5 (Nov 2021) NAM.14.47.47.453.306
For anyone following this thread still on the original pre-Barney UI and has hesitated to upgrade but mainly uses Car Play I just wanted to say I'm very much enjoying the new UI because I don't use AM/FM and mainly use Apple CarPlay and KIA Navigation. The map updates are GREAT and I don't mind the Funkadelic color scheme as much as I thought I would.
It was released in November. I don't think updating 4 months later is going to make you and early adopter.i'm not updating anything unless there is something awesome...we all know what happens when you update your iphone...bugs and battery drain...while there won't be any battery drain the bugs can be an issue...so unless they provide some new features that i need i'm good with the updates...everything seems stable at the moment...not worth the risk to be an early adopter or to adopt at all
still...what features did the update add that i need?It was released in November. I don't think updating 4 months later is going to make you and early adopter.
Don't know, but the update works fine for me. Despite what others think, I do think they are fixing issues with every update. Just like my TV, my smartphone, laptop. Updates are needed.still...what features did the update add that i need?
maps, for one.still...what features did the update add that i need?
wife runs carplay every time she gets in the car...she hasn't noticed any glitches with the rest of the features that i'm sure she doesn't use lolmaps, for one.
