3 ways for single hard button press.Trying to figure out how to flip back to CarPlay after leaving to mess with the radio or something. Is there a one button fix?
Great recommendations here.3 ways for single hard button press.
- Set your favorite button (the star) button to phone projection. Press and hold to set if needed. Should open straight to carplay when set.
- For Carplay audio, press the “Mode” button on the left side of the steering wheel. Press and hold to enable the option if needed.
- This third option only works if you are not on an active UVO subscription, press the UVO button on the the overhead console where the map lights are. Should open to carplay nav app last used.
This is exactly what I was looking for - I think my issue is projection wasn’t an option because I tried without phone plugged in.3 ways for single hard button press.
Is there any way to do a split screen with CarPlay and what's currently playing via audio (iPhone, XM, FM, etc)
I can't figure out how to show Google Maps and what my phone is currently playing or what my XM is tuned to - is it not possible?
Setup > device connections > CarPlay. Uncheck use split screen.
Make sure your phone is unplugged before you do this.
If you want to see your maps from your phone and what is currently playing on your phone, you have to make sure you have your CarPlay set to full screen (setup > device connections > phone projection/CarPlay, uncheck split screen). Then make sure the maps app you want is the one you used last. Then go to the CarPlay dashboard screen.I tried this but all I get is a full screen of Google Maps. I would love to figure this out. Thanks.
The easiest way to do what you want would first involve setting the star button to CarPlay (phone projection).I appreciate the help, guys. All I can accomplish is Google maps on 2/3 screen, and another map (apple maps?) on the right 1/3. If I bring up the car radio, it takes up the 2/3 screen, and the unwanted map app is on the right 1/3.
