Aside from the lacking 7-pin wiring harness and OEM brake controller, the disappointing figure when you look at the specs that overshadows the 5,000lb towing capacity is the underwhelming 351lb maximum tongue weight. While that's probably plenty to hang a few bikes off of, it can limit your options if you want to rent or buy a travel trailer. In case anyone can benefit from a little research, I dug into travel trailer options that would allow you to stay under 5,000 lbs GVWR, and the list includes small (20-23ft) travel trailers that had a hitch weight rating under 351lbs and sleep 5-6. The list is pretty short, but might serve as good starting point for anyone shopping for a travel trailer of this size not just for the Telluride specs for a minivan or another SUV with similar specs. If the max tongue weight were closer to 500lb there are a handful of smaller and even 22-23ft travel trailers that would have still fit the bill, but 351lbs limits the options some. (By comparison, when you look at most of the competitors to the Telluride they start at 450lbs (Honda Pilot) and most are at 500lbs., ex. Ascent, Explorer, Durango) So for example there are some nice options that are 18ft long that sleep 4 but their hitch weight rating was closer to 450lbs. Longer trailers allowed for the weight to distribute more thus lowering the hitch weight.
Regardless, the travel trailers below range between $10-20K USD used or new and all have a hitch weight rating under 351lbs with a dry weight between 2575-3750 that even after loaded up, will help keep you under 5,000.
