Frontal Collision Warning - Malfunction
That is not my issue. When I have the car in cruse control the car stays in the lane and maintains a pre determined distance with the car in front. That distance is maintained even as that car slows down and if it stops my car will stop. But usually it looses the car and I get a radar blocked radar disabled and it catches up to the car where I have to brake to avoid hitting it. Other times when I am following the car in front with the radar and a car slips in in front of me it will not see it and catch up to it where it will hit it if I don’t apply the brakes. I can usually work with a tractor trailer but not regular cars
my new 2022 Telluride has radar blocked issues. It turns the cruise control off. brought into dealer 6/6/22 and still waiting for their "technical assistance" to respond. they should read these forums.
My radar unit behind the front bumper was out of adjustment and was causing the problem. It took a year of coming back when they finally fixed it.
I get the beep warnings when someone ahead of me is making a slow turn while I don't slow down even though they're clearly no longer in my way.
We are also having the same issue with our 2020 Telluride. It's been at the Kia dealer since before Christmas and they've replaced every sensor, several wires etc. our dealer has been amazing but at this point I just want a new car. Kia needs to figure this out.
Does it on my 202, too. I've heard other manufacturers have the same issue. You'll be aware and get used to it after a while. :cool:
Has anyone experienced any malfunctions with the 2020 Telluride in regards to the Frontal Collision Warning System? My husband and I have had multiple instances where the FCW system has engaged sporadically when not neccessary causing the brakes to lock and the vehicle to slide needlessly. When we took it to the dealer to be inspected they found no error code and stated that the FCW system was only supposed to engage when cruise control was in use. The instances these "sporadic malfunctions " occurred cruise control was NOT in use. We were told to monitor the situation and try to log when and if it reoccured, time of day etc...Any others having this problem?
I have had this happen to my 2016 Kia Sportage. Dealer says they can't find anything. I'm afraid I will be rear-ended someday when the brakes apply erroneously.
