Driver's seat adjustment
dscott
I work for Lexus and our service dept uses techstream to do some personalized programming to the vehicle. Not sure if Kia uses this type system. Is there a way to raise the driver's seat higher than it will currently go? Wondering if there is some limit that can be adjusted.
I also have this question. I now that physically it's probably as high as it can go, BUT there are other brands that have after market "risers" and seat "spacers" that can get you your height. I've been so busy I've not had a chance to do this, but I had planned on taking the front seat out, then examining it for possible spacers.
Check this out
My issue is that I'm 6',5" and the front of the seat does not touch the back of my legs, moving the seat further back, is bad ergonomics. I need about an inch more and I'd be in GOOD shape.
If I get to test any of these, I'll def post here.
