Plastic Cover on Console by Gas Pedal
lyfbyts
SXP Model.....On small issue I have and would like feedback from others, can you guys check your plastic cover on the console down by the gas peddle mine seems so loose it rattles a bit. I don't know if it is just a clip that was not fastened or if there is no clip at the bottom edge and its just loosely fitty/flapping around. It will be apparent quick if you just nudge it with your foot.
Someone else mentioned this problem on another thread. Now if I could only remember which one ...
Thank you for the direction I found the post the person just said the fastener was undersized depth wise for the receiving clip so he added some soft side Velcro to the receiver and it tightened it up.
