berryboy808
- Jul 30, 2020
The Dam S only has the Fview camera harness. Pretty sure could still tap in but not to sure which wires I should tap. Gonna go buy a tester today. I just moved to Texas so had to get tools again. If I cant get it to work I will just hardwire tap to my dashcam already installed. SMHHello fellow Telluride owners!
One of the first additions I do to all of my vehicles is a hard wired radar detector. Since I did not see any instructions for this here, I decided to take step by step photos to help everyone else through the process. It's very simple and only takes a few minutes and keeps you from having to run a long power cord from the windshield to the outlet or down the A-pillar and into the fuse panel.
As a side note my Telluride is an SX with the Homelink equipped rear view mirror. So I cannot comment whether the mirror wiring will be exactly the same for LX, EX, or S models.
Let me know if you have any questions!
Items needed:
1) Radar Detector
2) Mirror power cable compatible with your brand of radar detector:
Example: Amazon.com: Xislet 15" Radar Detector Hardwire Power Cord Mirror Wire Plug Tap Compatible with Escort Valentine One Uniden Beltronics with Inline Fuse Mount RJ11 - Set of 3: Car Electronics
Example: https://www.amazon.com/dp/B01I1XF4XU/
3) Zip tie
4) Optional: rear view mirror radar detector mount compatible with your detector
Example: https://www.amazon.com/Radar-Mount-Magnetic-Detector-Bracket/dp/B0788WRVNB/
View attachment 12728View attachment 12729View attachment 12730
