Replace rear spoiler
Charlottegirl
Hi!
Has anyone had the rear spoiler replaced? If so, how much did it cost you?
Best start is to go to the dealer to see if it is a part that can be ordered. Once you get the part number, you can shop around. Car parts are weird is some ways in that parts can only be ordered as one unit, as if you need to order the entire roof section. Hopefully this isn't the case.
Thanks for the reply! I looked into it and found the part online for $450. It’s a single part but it needs to be painted and then installed.
Maybe check out a junk yard for a wreaked one in the same color. Might save you money on the part and paint. at least eliminate that as an option.
Depending on your insurance, turn it in on a claim?
