and 1 more, where did you guys order from? im seeing multiple places online. was hoping for free shipping somewhere!Yes it is
I bought mine from the local Kia dealer here in South Floridaand 1 more, where did you guys order from? im seeing multiple places online. was hoping for free shipping somewhere!![]()
I ordered from eBay…it did not include the instructions like the descriptions said but I found a pdf posted on this forum. Best deal I could find that looked legitimate.and 1 more, where did you guys order from? im seeing multiple places online. was hoping for free shipping somewhere!![]()
Curious with the peanut gallery thinks of this. Does not require any splicing so would not void warrantyThis looks really great! I am new here... got my SX-X line last week and only then discovered the whole hitch thing... speechless...
Just to confirm - is the part S9F61-AU002? I saw some earlier post that the OEM hitch doesn't totally fit, maybe it was referring to S9F61-AU000..
Will try to get this in and install..
did you guys install them yourself? i thought i saw somewhere on here that they werent the exact fit, and had to add washers or somethingI ordered from eBay…it did not include the instructions like the descriptions said but I found a pdf posted on this forum. Best deal I could find that looked legitimate.
I ordered one of those but ended up using the unbranded converter that came with my stealth hitch. The Tekonsha seems like a really great option. My only concerns were 1) will the sensors fit behind the brake lights, because if not, getting to the wires behind the interior panel is a pain in the neck, and 2) probably an unlikely concern, but since the led tail lights use little current, will the sensors reliably sense the current?Curious with the peanut gallery thinks of this. Does not require any splicing so would not void warranty
tekonsha.com/product/119250_zero-contact-universal-modulite
I agree.I finally got my $1,200 back from the dealer for hitch parts that do not exist. It is still hard for me to digest the idea that the salesman scammed me into paying for parts that do not exist in order to close the deal (he could see that I was not going to buy without a hitch). He still says he did not know the parts are not available even though the information is readily available on the Internet including here.
BTW, neither Kia Corp nor the local sales manager made any apparent effort to resolve the issue even though I reported it to both. Customer satisfaction does not appear to be a high priority in Kia. I am not looking forward to a long relationship with them.
Dealer told me shouldn’t be more than 6 months but we’ll see. I don’t need a hitch right away so it’s not really a deal breaker for me. Just hope they eventually figure it out. Thanks for the info.Choosy, when did your dealer predict your new order will arrive? Our Telluride arrived 3 weeks ago sans hitch after an 8 month wait. My dealer estimated the trailer hitch situation will be resolved sometime around September. I plan to install the 2022 hitch without wiring harness next week, part S9F61-AU002. It is the wiring harness recall that is causing the issue and delay which I do not need immediately. Others have already installed this part on their 2023s. I will post what I find out.
When you say under the dash I presume that means for the wires electronic brake controller. Did the installer tell you which wires in the 7-way round work? For example, do the basic 4-wire flat function work? (Left, right, running, stop)? If so you could use the 2022 harness with an adapter to get 4-way right away and if the pin for power is hot you could use an echo wireless brake controller. If no power nor cabin wire but all others work you could run to an auto resetting breaker and tap that into the harness. You would basically be in the same boat as the 2020 owners but with an easier way to get an OEM 7-way to work.I just tried a Curt wiring plug-in harness that fit the 2022 Telluride. But when my auto shop tried to install it, the repair guy said there is no plug-in receptacle where it's supposed to be under the Telluride dash.
So there's current no way any wiring harness will work.
When I was in the process of buying my 2023 Telluride in January, the salesperson told me "We owe you a wiring harness." So he knew about the lack of one and was forthright about it. But no one had any idea when they would be available.
I guess I have to keep my 2017 Sorento now instead of selling it until this gets resolved.
I did install the hitch install myself-saved $350 in labor according to a dealership that quoted the install. There is a about an 1/8” gap before you torque the bolts so that it has an easy fit up. torquing the bolts in the prescribed sequence in the instructions will close the gap up. they intentionally have you torque the smaller 7/16” bolts first to set one side snug to the frame as the larger M12 bolts flex the hitch frame to close the gap on the other side when they are at full torque.did you guys install them yourself? i thought i saw somewhere on here that they werent the exact fit, and had to add washers or something
Interesting…. can you tell us where you saw this info posted about the 2024s coming in July?It’s not the wiring that’s a problem it’s the tailgate latch. The tailgate has been known to pop open on a tear end hit on Tellurides equip with a hitch. They were told to no hitch’s until they redesign a new latch….Hitch’s will be on the 24 Model coming out in late July
I have a tough time believing this is the cause for the delays without more context and references. Not a single person on this forum, that I have seen, has complained about the latch not working properly. Is it it only the power liftgate latch or what about the non powered ones? I struggle with accepting that Kia would be holding back the ability to tow officially because of a latch issue that is going under reported.It’s not the wiring that’s a problem it’s the tailgate latch. The tailgate has been known to pop open on a tear end hit on Tellurides equip with a hitch. They were told to no hitch’s until they redesign a new latch….Hitch’s will be on the 24 Model coming out in late July
