Slack Attack
- Feb 20, 2021
Agreed on the self leveling suspension, certainly not a necessary component to towing with the Telluride.I disagree. I think people are having success ordering the Hyundai part for the tow harness and it appears to be a very straight forward plug and play answer that effectively solves the 7-pin harness problem perfectly. If you don't want to install the hitch yourself, you can take it anywhere to install by a professional for a couple hundred dollars as it involves putting it in place and torquing some threaded bolts. I think the evidence on this forum is that the self-leveling suspension provides a questionable, at best minimal, towing benefit for some light towing, but for more regular towing you may wear them down faster, they are more expensive to replace, and you can't replace with regular shocks. You typically want more rigidity when towing which the leveling shocks tend to do the opposite along with make it a little more complicated to load level since you have to account for the self-leveling. There have been people also report that the self-leveling shocks have a more pronounced sag when parked. If you like the self-leveling rear suspension during normal driving as a comfort convenience more power to you, but you don't need it to tow with a Telluride.
Everything is a compromise as there is no perfect vehicle. If you want a vehicle that has a more thought out towing package, go with a Nissan Pathfinder that has a body on frame like a truck vs unibody on the Telluride. But I'm sure you will find a compromise in something else.
As for the Hyundai Palisade 7-pin harness, I just want to point out to folks that some members on this forum have waited 3-5 months for the part and so availability is not instant like we have come to expect. For anyone buying a Telluride this summer who needs to tow this summer, it is just going to be a challenge.
Of course, for people who only need a hitch for things like a bike rack, that can be resolved immediately with a number of good solutions.
