I had the dealership install the hitch, a 7 pin wiring harness and brake controller. It's all neatly contained in the bumper enclosure so looks like it should readily accept a 7pin wiring harness. I don't know if doing it yourself voids the warranty, but the Telly should be set up to accept one. We had no problems with our 2016 Sorento with a 7 pin harness and brake controller either.Has anyone hard wired a trailer brake switch? If so did it cause any problems or is everything as smooth and operating properly? I’m worried about messing up electronics and voiding a warranty!
As far as I know from the info and brochures, the self leveling should already be installed on SX Prestige, in Canada at least. But the whole towing specs and what the towing package actually includes seems to be an enigma with Kia vehicles. I think they are already prepped for towing, and towing package is the hitch, wiring etc.Good morning,
When the hitch is dealer installed, does the rear self level still? Is there a software flash of sorts?
We just placed our order for a SX Prestige and they forgot to add the tow package to be added during the build. The build hasn’t started yet so I’m hoping they can get the order corrected before the build starts. But if they can’t, I’m curious.
Thanks
Sounds good.. thank you. I will do some research so I know what to expect, either way the hitch gets installed. Thanks again.As far as I know from the info and brochures, the self leveling should already be installed on SX Prestige, in Canada at least. But the whole towing specs and what the towing package actually includes seems to be an enigma with Kia vehicles. I think they are already prepped for towing, and towing package is the hitch, wiring etc.
No problem. Depending on what you're towing, you might want to insist on a 7pin harness instead of 4 pin.Sounds good.. thank you. I will do some research so I know what to expect, either way the hitch gets installed. Thanks again.
Does anyone know how you can change the 4 pin to a 7 pin? We have the tow package on our EX from the factory. We have a boat and we only tow it twice a year, once when we put it in the water, and once when we take it out of the water. Our trailer has a 7 pin so the tow package is useless to us as it is. Any suggestions?
The 7 pin connector that I used for my sienna had a 4 pin input in the back - this takes care of the brake light and turn signals. There were other individual wires that you had to connect if you wanted brake power / reverse lights and +12v power.
So if you just want the brake and turn signal functionality (no electric brakes or anything else) I think you could just buy that connector and be on your way.
I think this would do it:
Adapter 4 Pole to 7 Pole and 4 Pole w/Test Lamps Curt Wiring C57674
This multi-function, vehicle-end connector converts any 4-way flat, vehicle-end plug to a combination 7-way outlet and 4-pole flat outlet. Lowest Pricwww.etrailer.com
You would want to make sure the mounting point for the current 4-pin connector would accommodate the 7 pin connector if you want it mounted permanently. You would also have to decide if you want to go through the trouble of running the additional wiring for the electronic brakes (and brake controller).
How heavy is the boat, and how far do you tow it?
Also I would make sure it is a 7 pin connector. I know nothing about boats, but I know there are 6 pin connectors out there for some trailers, so you want to make sure what you have. (Both are round, but not compatible)
Steve
The boat with the trailer is @ 5,000 lbs. We trailer it @ 14 miles and only twice a year. Yes we definitely have a 7 pin connector We used to trailer it with my Tahoe which does have a larger tow capacity.The 7 pin connector that I used for my sienna had a 4 pin input in the back - this takes care of the brake light and turn signals. There were other individual wires that you had to connect if you wanted brake power / reverse lights and +12v power.
Steve
Agree We love the Telluride so far. Even if we have to pay someone to put our boat in and out of the water a couple of times a yearYeah, I totally understand what you are describing. Kia got a lot of things right with the teulluride, but they screwed the pooch with the towing (and payload) specs / setup.
I suspect they will clean it all up in the near future, but us “early adopters” have to deal with the growing pains.
Well you still got the hitch and self-leveling system. Time to go to U-haul and have them install the proper wiring with the 7 pin connector and be done with it.We have surge brakes on our trailer. The issue is when we put our car in reverse while towing, the brake controller on the trailer will activate and lock the brakes and that would mean we would be "pushing" the trailer with the wheels locked. We need the 7 pin connector to tell the trailer we are going in reverse. Hard for me to explain, but does this make any sense? Kia should have done it right. If they said tow capacity was 1500 lbs that would be understandable with a 4 pin connector. The fact Kia said the Telluride can tow closer to 5,000 lbs and put a 4 pin connector is just stupid. Don't even get me started that we paid almost $800 for it!
