I've read where there is no bottom shield on the Tellys. Looks like it was designed for one, but KIA left if off.Which FUMOTO valve is best so you don't have to modify the bottom shield? Any other valve options? Thanks in advance
Can’t comment on 23 or later but there’s a shield that needs removed.I've read where there is no bottom shield on the Tellys. Looks like it was designed for one, but KIA left if off.
Well somebody will soon comment on what is there from DIY oil change.Can’t comment on 23 or later but there’s a shield that needs removed.
From a picture I saw, this must be the relatively small plastic shield that is in the large opening?Yes, you have to remove a shield to gain access to the drain plug and oil filter.
I'm going to order and have dealer install it at my 1st oil change. Going to use mobile 1.Yupper, need to remove to access filter and prevent mess if you open drain bolt.
The only problem with Mobile 1 is that it does not meet ACEA A5 standards, which is specified in the Telluride manual (page 9-5). Another member here told me today about Pennzoil Ultra that exceeds ACEA A5. Castrol Edge also exceeds ACEA A5. I am going to use the Pennzoil because I researched a comparison between the two:I'm going to order and have dealer install it at my 1st oil change. Going to use mobile 1.
I always figured the dealers used some off-brand that was cheaper.Sure, but mobile never tried to meet the European spec and you know that the dealers are not using pennnzoil or Castrol either. This is my third telluride and the dealer uses my mobile 1. If they actually install it is unknown.
If you are going to have the dealership change your oil I would not buy it. it drains slowerI'm going to order and have dealer install it at my 1st oil change. Going to use mobile 1.
7.08 is a dry fillThe only problem with Mobile 1 is that it does not meet ACEA A5 standards, which is specified in the Telluride manual (page 9-5). Another member here told me today about Pennzoil Ultra that exceeds ACEA A5. Castrol Edge also exceeds ACEA A5. I am going to use the Pennzoil because I researched a comparison between the two:
"The main difference between Pennzoil Platinum oil and Castrol Edge is that Pennzoil Platinum is formulated for a better fuel economy and is more resistant to heat-related damage. Pennzoil Platinum oil is derived from natural gas while Castrol Edge oil is formulated from a mixture of castor oil (derived from castor bean plant) and petroleum-based lubricants. Pennzoil Platinum prevents carbon deposits and sludge due to detergent and produces less smoke compared to Castrol Edge motor oils. Both Pennzoil Platinum and Castrol Edge oils are best-selling synthetic motor oils in the United States. They are similar in consistency but differ slightly in their formulation. Both oils will protect the engine from wear and tear."
Remember the Telly takes 7.08 qts.
One last thing - not sure I would trust any dealer to use the oil you bring them. Not sure why I feel this way, but I don't have the same fear for my local mechanic.
You'd think they would tell you this - geezIf you are going to have the dealership change your oil I would not buy it. it drains slower
7.08 is a dry fill
6.87 is a service fill.
I put 6.5 in
It is in the manual.You'd think they would tell you this - geez
Thanks, saved me from buying an extra quart!![]()
You're a better man than me - I can't find it and I've looked and looked.It is in the manual.
In the 2021 manual it is section 8 page 9You're a better man than me - I can't find it and I've looked and looked.
Ok - I'm looking in the 2024 manual, and it's not there that I can find.In the 2021 manual it is section 8 page 9
Also if you go to any motor oil website and search by vehicle it will have the capacity.
Exactly - that's the only thing I found per my post #10In the 24 manual on page 9-5 it says 7.08. Which is strange since it is the same engine as previous years and is the same exact amount as a dry fill.
