patrickm22k
- Sep 6, 2023
Sometime in the past 2-3 months I received an update for my Kia (I don't know exactly when I was overseas). I installed it, and regret it immensely.
Before the update, as soon as I turned my car on I had a split screen display of (Map|Radio|Weather). Now when I turn it on, I have a "stylish" screen with the time in the bottom left, and as you move to the right a barely visible map is visible (barely visible because it's purple and hard to see). I tried to go back to the old way, went to settings, found display/split screen... and my split screen has the order of (Map|Radio|Weather)... but this never appears to work. I tried enabling all split screen options... never works. Has anybody had this problem and figured out the fix?
I also noted a weird quirk- it used to be when you turned the car "off", the radio/acc stayed on for 2-3 minutes or until you opened the door. Now, as soon as I hit off- literally everything changes. Is there a way to reset it back to the "stays on for 2- 3 minutes" option? When I've backed into the garage, it would be nice to finish a phone conversation while sitting there without the car on (I don't want to pump exhaust into the garage while I finish a call).
I've turned here in case you all have had the same issues and found fixes. If not, I'll run to the dealership and ask them and likely see the same confusion... think that might lead to an equal exchange of my 2021 for a new model where the system works?
