I haven't seen this mentioned before, so thought I'd add it to the knowledge base...
Hooked our small cargo trailer up yesterday and noticed something that might be of interest to those of you who use the hitch for bikes and similar loads.
After hitching the trailer up (and before connecting the lights), I did a quick test and found what others had seen. As soon as I tried backing up, got the beeps and emergency braking. As expected.
I then plugged in my 7 pin to 4 pin adaptor and tried it again. No beeps, no emergency braking! So those of you who use the hitch for anything other than towing, this can be a solution to the backup alert/braking issue!
Note that is with the (
Palisade) wiring harness, and my 7 pin to 4 pin adaptor which has very small LEDs to aid in troubleshooting by testing the vehicle wiring.
Mark
P.S. Forgot to mention the trailer lights worked perfect, and the effect of towing a 1500lb trailer was almost unnoticeable (other than some extra bouncing)
