Will these tires/wheels work
eiskafee
I have a winter wheels and tires set from my BMW X3. The size is 245/50 R19 105V (These are runflats too). The official sizing for Telluride is a little different. Can anyone tell me if these will fit my 2021 Telluride SX Limited. Thank you in advance.
They’re an inch shorter which will cause wear issues, more importantly you need to verify the bolt pattern and offset will work.
You need to check wheel size for starters - you say your BMW wheels are 19 inches whereas the Telluride comes with either 18 inch or 20 inch wheels. So that may present an issue from the start.
Beyond that the bolt pattern has to match, which in this case is unlikely as the BMW bolt pattern is typically 5 x 112, whereas the Telluride bolt pattern is 5x114.3
Then there is the matter of wheel offset, but given the two factors already mentioned you will not reach that part of the discussion.
Sorry to be the bearer of bad news.
Thanks for your help. You are correct, I did some research on GPT and found the same answer. The bolt pattern is different and these are incompatible. Thank you once again.
You're welcome, happy to help. There is a lot of good info on this forum and good people willing to help, that's what makes it a great place.
