Seeing as we are showing off our rims. Here are mind I had installed on 04-15-2022.DSCN0038.webp
Anyway you can bolt them up and check for rubbing? You're gonna be close
I bolted up one on the front while lifted, but haven't got the tires yet. Looked fine and didn't poke too much so I think we're fine; just being cautious.
I mean I'm lowered with my setup but I have 9" wide with no rub, the concern I think would be lock to lock rubbing but also depends on the offset.
Any pictures of your set up and what’s your offset on the wheels?
Howdy!
Thanks to my father's tow-truck business, and some poor driver's misfortune, I lucked into these beauties from a wreck for the low-low price of $200.
No idea what brand they are (no info on the inside and no center caps), but I did a test fitment and they appear to fit fine, though these are absolutely NOT the tires I'll be using lol.
They're 22x9.5... ET15 😬. That offset worries me a bit, but it LOOKS like they'd be ok. Considering 285/35/22 tires. If there's something I'm missing, please somebody let me know before I go out and buy these tires :LOL:. Thx in advance!
The rims will poke 26mm in the front and 21mm in the rear, tire bulge will add some poke too. Those are very aggressive offsets for a Telly.
Not sure about the 20"s but the 18"s are 49.5mm I installed a set of 20"s (Helo 894) with 38mm and probably most aftermarket wheels are less than 49.5. Its pretty much a non issue. At 38MM the tire will be slightly closer to the outside of the wheel well than stock. I cant really see much difference but Ill post a front on shot if anyone is interested.
Yes I’m interested, I’m wanting to put 20x8.5 rims with a 40mm offset, I want it right at the wheel well, 760-343-8482 if you want to text me some pictures, thank you
Just upgraded yesterday. Niche Mazzanti 20x9 +35 wrapped in Falken Wildpeak trail 275/45/20. No rub so far. Tires suck up bumps much better than the factory Michelins.
Alright, after many months of sitting in my garage, I finally got tires on these and had them put on. They poke JUST a lil bit, and no rubbing thankfully. I did have to add some hub rings to make the bore match up with the wheel and get rid of some vibration
22x9.5" ET 15 on 285/35/22 tires.
