Domenico
After a snow storm that disabled the forward radar, the parking sensors stopped properly working. Currently, the parking sensors do not signal when I closely drive forwards next to an object. If I put the car in reverse and immediately shift to drive, the sensors work. The dealership has acknowledged that the problem is present; however, because an error code doesn't exist, they cannot fix it. The software is current. The dealership said that the fix could be replacing the module, which cannot be done with an error code. Otherwise, I will just need to wait and see if a future software update will solve the issue. The dealership recommended that I call KIA customer support and explain the issue and situation. Before I do, has anyone experienced this problem? I am hoping to present more than the problem to customer support. In the meantime, I will try disconnecting the battery for a while and then attempt to install the current software version.
2022 Telluride SX Prestige
