i have a 2020 telly EX 118k miles and i just replaces both front units same thing leaking, it was found by dealership but i had it replaced at FIrestone for cheaper $Our 2021 Telluride with 15K miles has a leaking passenger side front inner CV boot. Unfortunately, the dealer is back ordered on the boot with no ETA. Looking at it, it does not appear to be torn. The grease seems to be coming out right at the end of the boot after the clamp. Has anyone had any experience with loose clamps or leaking boots?
Has anyone replaced a boot yet? If I can find the part I may just do it myself.
Thanks for the info.
I am having the same cv boot problem and warranty issue. They quoted me $2,900 to fix it. Local shop said $2,200. Either way it sucks. Spoke to truxxx and of course they said this shouldn’t happen.Our 2021 Telluride with 15K miles has a leaking passenger side front inner CV boot. Unfortunately, the dealer is back ordered on the boot with no ETA. Looking at it, it does not appear to be torn. The grease seems to be coming out right at the end of the boot after the clamp. Has anyone had any experience with loose clamps or leaking boots?
Mostly the clamp , it's a big issueSame. Passenger side CV boot leaking At 66k miles. need to investigate if torn or clamp leaking.
That should be covered under warrantee and they should provide a loaner or get you a rental on their dime.Our local service garage mechanic just called me and told me the exact same! Our right axle boot is blown out and throwing grease everywhere. I'm at 39,000 miles. Had a big trip planned to tour colleges for my twins and now no car. Dropping off to the dealership tonite. They won't order the part needed until they see it and no loaner car. Sucks!
You are completely right. It will be covered under the factory warranty.That should be covered under warrantee and they should provide a loaner or get you a rental on their dime.
What is the intermediate shaft issue?Had to fight with dealer but they ended up replacing the whole CV axle. No cost to me.
No I see there is a recall for intermediate shaft problems.
Same thing over here. We bought new tires...it is still vibrating and shaking the whole car. It usually happens at high speeds but is not constant. Sometimes it lasts along time, then goes away and comes back 20 - 30 min later. We notice it more on the freeway and especially when we have longer road trips. It is scary!Our local service garage mechanic just called me and told me the exact same! Our right axle boot is blown out and throwing grease everywhere. I'm at 39,000 miles. Had a big trip planned to tour colleges for my twins and now no car. Dropping off to the dealership tonite. They won't order the part needed until they see it and no loaner car. Sucks!
