Do I have the correct Cargo Net for my 2020 Telluride?
RonInNJ
Monroe Twp, New Jersey
I ordered a cargo net for my 2020 Telluride EX and received one with a KIA part number 59F17 AU000. but, when I installed it according to the instructions it doesn't seem to fit. It seems a bit too narrow but more importantly the loop ties on the side are both situated at the same position but the built in hooks the loops hook onto are not at the same level, with the driver side hook substantially higher then the passenger side hook. This results in the net being slanted which I cannot believe is the intended finished look. Yes, when I bought it I had the make and model selected that matches my Telluride. Do you think I have an incorrect part?
View attachment 4213 View attachment 4214
Seems like right part number... but that can't be right. See guide...
I do not have this cargo net but the size looks exactly the same to me as in the accessories guide. The only difference that I can tell is that the location of the upper tie down. It seems too far forward. It should be directly above the bottom tie down.
Same one that came with my Telly...
I lay mine flat in the cargo bay and use it like a "tie-down" by slipping items under the net.
Looks right to me but I think you have the net anchored in the wrong place. This is how I use mine. Don’t connect the cargo net to the seatbelt buckle holders. Those are more fragile and they will break. The round anchors are more solid and at the same height and will put your net vertical.
Here’s a close up on how to stow the seat belt buckles when the third row is down. Use the round anchor for your cargo net. That one is less likely to break.
Yep it's the right cargo net. I'm really disappointed in how narrow it is, things on the floor can get right past it.
What a sad looking cargo net. Not wide or tall enough to be useful.
That was my concern, that they did not compensate for the larger size of the Telluride and just assigned a smaller existing net as the option for the Telly.
I should've kept the one from my sorrento it would have fit better
I might be the only one but I think it works fine. I’m able to secure the cargo enough to open and close the hatch without anything falling out.
Not sure what you guys are talking about, my net keeps small items at bay, they don’t slide under.
