Dandy
It may be an easy fix for a trailer place, but it is an additional expense and how good of a job will they do. Also, if there starts to be some sort of wiring "gremlin", the dealerships will often point to any aftermarket part wired into the vehicle and the finger pointing begins. Believe me, the company I work for makes 3rd party add ons to agricultural equipment. Our team has had to gt to know the equipment that ours is attached to very well and we end up helping to diagnose their issues because the finger is usually pointed at us. In our newer designs, we have gone so far to include methods for clients to verify that our system is running correctly and the issue falls on the item it is attached to. We even have a supply of data loggers that we send to clients so that we collect hard data to determine where the issue is. If a company is going to rate a vehicle for 5K towing, they should include the necessary components to do it safely and legally. I am willing to bet that a lot of people are unaware of what the legal WEIGHT RATING of the trailer is in their state where brakes are required. Yes, it is based on the WEIGHT RATING and not the actual weight of the trailer.Am I missing something? It sounds like this is an easy fix. UHaul or any trailer place will install a brake controller and 7pin harness adapter for a couple hundred bucks at most. The more important thing is that the vehicle can pull with a class III 2” hitch receiver. I’m just confused why one seemingly simple fix would be cause to spend thousands more on another comparable vehicle.
^^^^THIS^^^ Stopping is the largest issue in safety when towing. Given enough time, vehicles can easily pull and get up to some speed towing, but they cannot necessary stop. When I tow a trailer with electric brakes, I go so far as setting up the controller to brake the trailer slightly harder than my truck. This assures a straight braking path so that in an emergency the trailer is not pushing the truck. I adjust on every tow, because of the change in weight. I could not agree with your statements in this thread more!You are dead wrong. The most important things about towing are cooling (for towing up hill), load leveling (for headlight and steering safety) and most importantly: braking. Bad trailer braking characteristics is the #1 cause of trailer related accidents... and the Tellie is not designed for proper towing braking. Almost any vehicle can ‘tow’ (on the flat). That is the easy part.
