These look great , are you doing a square set up or staggered , what do they cost ?? what do they weigh ??
Thanks
32 pounds, curious what the stock 20"s and 18's weigh, I'm replacing the EX 18's. Priced great, around $170 US. I've had Helos before and was very happy with them.
Im going with these, sure they will fit. Helo shows them as compatible.
  • Offset: 38mm
  • Backspacing: 6.25"
  • Max load: 1900 lbs.
  • Centerbore: 72.60mm
  • Diameter: 20"
  • Width: 8.5"
  • 5 x 114.30mm Single Bolt Pattern
I'm leaning in the same direction. Love those wheels.
I am going with 22s and have a new set of brake calibers in order to have painted red. Pretty excited!
  • Offset: 38mm
  • Diameter: 20"
  • Width: 8.5"
Please post pics to this thread after you get these installed. I may go the same direction for winter wheels/tires. That's a good price and I think an old friend of mine sells Helo at his shop.
I will install/post when the EX gets out of the shop!!! New wiring harness @ 280 miles?? Ill make you a great price on the EX 18's if you want them for winter tires.
That doesn't sound good. I may be interested in your 18's. Does this forum have a private message function? At quick glance, I can't find one.
i just sent you one its in members profiles
OK... it doesn't work for me. Every time I click on one of your names to get to your profile, I get this message:
826
Maybe I need to have a minimum number of posts on the forum before I can post on member profiles.
I got your message.... I will email you shortly.
What size tire did you put on those? I was looking at same ones but think I want 255/50/20 instead of the 245/50/20. Thinking Toyo Proxes ST III for tires
  • Offset: 38mm
  • Diameter: 20"
  • Width: 8.5"
only place I would dbl check is centerbore cant remember if its 74.1 mm or 72.1
Stuck with factory sizing...the 255/50/20 is 1" greater in diameter @30" so would have some impact on speedometer accuracy...not much maybe 1.5% so probably not a big deal...
this past weekend, i did a test fit of my old Axis Model 5 and they fit perfectly. the specs are 19 x 8.5, 114.3 bolt pattern, 35 offset. i am still deciding if i wanna use this wheel set or get new ones. decisions, decisions, decisions. LOL!View attachment 370
what size tire is that? (It looks taller than the 245 stock size in the rear)
morning!
the tire in the front is 245/55/19, while the size in the back is the stock 245/60/18. the perspective of the photo is making the front tire look way bigger.
What are you doing with the rims the car comes with ? Easy to sell ? Considering the same for the EX
yo! brandon, check out discount tire direct. they have the telluride listed. tire rack doesnt have it listed yet.
Good advice. I checked them out and they do have ones like the attached screen shot. Have to buy the TPMS sensor so its another $180 on top of it...I just need advice on what to do with the existing rims as they are nice...the chrome does match the chrome on the EX so its a touch choice.
I know nothing about tires and rims other than I want to change the stock rims on my S to black ones. Suggestions?
