reigndeerz
Just completed LED upgrades across all the lights on my S Trim and confirmed that it all functions without error codes and hyperflash.
tl;dr
a) LED Bulb Purchased + Cost
b) Ease of Installation
c) Installation Guide
d) My Personal Take
e) Before / After Image
1. Headlamps
2. Front Turn Signal
3. Front Side Marker
4. License Plate
5. Backup / Reverse
6. Tail
7. Brake
8. Rear Marker
9. Rear Turn Signal
Great write up, thanks for investing the time and effort to see what works. Looks great! On the headlights, does it require low and hi beams?
Also, on the reverse lights, when I click the link, it tells me they don’t fit. Am I looking at the wrong item?
Nah, just it's just a single 9005 bulb.
Amazon pretty much says nothing fits the Telluride, so I just end up ignoring it. You just have to find the right bulb size and you'll be fine.
@reigndeerz ,
have you tried Osram lad? Is there a bug on the brake lights?
Are the turn signals working normally or has the blinking frequency changed?
@reigndeerz ,
Have not tried Osram, sorry.
Turn signals are perfectly in sync as originals. I always change one side first to verify that it works just like to original halogens.
9. Rear Turn Signal
Alas, I tested the rear turn signal using the hazard light button and it did not hyperflash / error message, but it hyperflashed and showed an error message when using the actual turn signals on my first drive.
I'll be spending another 45 mins or so replacing it with the LASFIT bulbs used for my brake lights, if not with the Everbright bulbs used for my front turn signal. Keeping my fingers crossed as did is by far the worst bulb to be replacing!
Thanks for taking the time to post and explain the process. I was hesitant at first but I think I’m gonna give it a shot. Keep us posted of any other issues!
Happy to report back that the LASFIT bulbs used for my brake lights worked perfectly for the rear turn signals! No errors and no hyperflash!
Here are some additional tips for those attempting the rear turn signal upgrade:
- Get a 9/16 hex screw driver to open the driver side casing. Makes life MUCH easier.
- Also pull down on the cover when unscrewing or it may not quite unscrew.
- Notice the base position of the halogen bulb as you unscrew it and hold your new LED bulb the exact same way when screwing it back. (the 1157 base has 2 pins that are offset at different heights)
- Notice the orientation of the power cables at the connector before twisting. It'll help with your orientation when trying to twist it back in after swapping out the bulb.
This is the exact info I needed. Looking to upgrade my headlight on my 21 S model. How is the “down the road” enhancement over the original halogens? Also are the 9005’s the 6000k variety? Thanks in advance
now if we could only get both sections to light up when the brakes are actuated. Like the stock LED assemblies
Have been running with the upgraded headlights for 2 months right now.
Very satisfied so far and no issues whatsoever.
yes, confirming that the 9005s are 6000k. :)
Looking at the Lasfit website and they list different wattages. Which wattage did you chose?
60W. I linked to the exact item I purchased in my original post. Get it from Amazon as it's cheaper than the LASFIT site.
Thanks; appreciate all your help
Only thing I’m worried about is by removing the desiccant it’ll build it moisture. Not sure where you live but I’m in NJ so idk if it’ll be a issue.
Do you need a tool to remove the back cover to get to the backup/reverse lights?
Purchased the Lasfit headlights based off of reindeerz recommendations from Amazon (they were definitely cheaper 👍). Delivery set for tomorrow
