Went on the first night drive for me with the Lasfit; these lights are so bright. Wife and I love them. Is there anyway to adjust the aim; maybe a click or two lower. It’s something I’ll have to mess around with but not sure if the assemblies are adjustable. If not; oh well
There's a thread floating around the forum on how to click down the headlights. Search for "LED lights too bright?"
I had to lower the driver side headlight because it was too high. There’s a 10mm grayish bolt in the back of the unit. Pretty noticeable. Play around with it to adjust the height you want.
I purchased the 1157-R LASFIT LED bulbs for my brake lights. I installed them tonight and both of them were flickering when the vehicle running. They also seemed loose while in the socket. I could move the bulb with my fingers and it would turn them on and off. I will be returning these bulbs to Amazon. Does anyone have another recommendation for LED brake light bulbs?
Hmm. That's weird. Mine have been working perfectly fine. It sounds like your connection is loose as you should not be able to move the bulbs once locked in.
If you look at my initial post, the amber front signal lights *should* also work for brake lights when ordered in Red. There's also a set of brake lights from Headlight Revolution that I was eyeing if the LASFIT did not end up working out for me.
I know reading your previous posts you couldn't, but is there any way you could get a side by side, night shot comparison of the rear lights on and then with the brakes being depressed?
Has anyone else noticed a big difference in backup camera image quality after switching the reverse lights to LED? Did it make enogh of a difference to justify the work of having to remove the back panel?
My wife and I both did.
Follow the install pics from a previous thread for the panel removal, but its pretty simple even if you are not a gear head.
Just completed LED upgrades across all the lights on my S Trim and confirmed that it all functions without error codes and hyperflash.
tl;dr
a) LED Bulb Purchased + Cost
b) Ease of Installation
c) Installation Guide
d) My Personal Take
e) Before / After Image
1. Headlamps
View attachment 13006View attachment 13007
2. Front Turn Signal
3. Front Side Marker
4. License Plate
5. Backup / Reverse
6. Tail
7. Brake
8. Rear Marker
9. Rear Turn Signal
So, I’ll preface with this might be a dumb question, but the linked lights say high beams....does that matter?
The Telluride only uses 1 bulb for both regular and hi beam. Ive also not had any issues, so think you should be good :)
Me either; I installed the same bulbs and haven’t had any issues
Thank you for this post! Thankfully, the 2021 EX Premium Tellurides come with LED headlights, but my license plate lights were still halogen so I just replaced those yesterday.
tl;dr
d) My Personal Take
1. Headlamps
4. License Plate
5. Backup / Reverse
6. Tail
7. Brake
8. Rear Marker
9. Rear Turn Signal
I just tried installing the headlights, and they did not come on and threw the error as well. Then I took it to a mechanic well-versed in led headlights and he couldn't make them work. I have a 2021 EX. Frustrating to say the least.
What headlights did you go with that did not work?
I have the Auxitos and they are really nice. I know they get some bad reviews from some on her, but they have been solid for a year for us. I am about to convert to the SX led headlights to eliminate the low quality halogen and upgrade bulbs once and for all
Converting to the SX, is that where you are replacing the entire headlight assembly? How much does that cost?
Well that also depends on how lucky you get on ebay, junk yard or where ever you find both intact assemblies with all parts. There is a great thread you can go through, EX to SX headlight upgrade in the search column, or just looked up member name Machtig. He is the one responsible for putting the wiring kit together to make it all possible on the lower trims.
Back to your question, I paid $650 for bothe headlights from a seller and then $350 for the wiring harness. It seems like a lot, but when we bought our S 2 years ago, the EX only came as an 8 seater and the SX was like Bigfoot, heard of, but never seen on dealer lots. So I am still well below what I woukd have paid for an SX doing the upgrades I want on our S. Next hopefully the LED taillights...
Interested to see how the rear LED coversion goes. I replaced the front halogen with Lasfit LED bulbs (work good for me, no dark spots with a adjusting) I just wish I had the rear LED lights. I am willing to bet if someone had the know how and a factory scan tool, the change from incandescent to LED assembly’s is a simple program setting in a body control module. From what I have gathered in other threads, the wiring harness is very similar for both assembly’s. I wouldn’t think there would be drastic internal hardware changes for incandescent vs LED, but I could be wrong.
