Gas Gauge
Well, my new 2023 Telluride fuel reading went to ZERO with no range estimate (--) on our first road trip 400 miles from home. We were only on our 2nd tank of gas. The tank indicated 1/2 full when we turned the car off then registered empty the next time we started up. The next day and several starts later, it started reading accurately again. Seems more like a software error than a sensor issue.
BTW I've only filled the car up 3 times, but it has consistently clicked off at the pump with a 1/2 gallon still left to fill. So, I have been letting it click off the first time, then go only one more click-off.
I usually gauge how much it should fill based on the gas gauge on the dash and 18 gallon tank size. So if you have half a tank, should be able to fill close to 9 gallons. If it clicks off as soon as you pump or way to early, it could be an oversensitive handle-off trigger. So if that happens I keep the handle sideways and it usually fills up properly before it triggers off accurately when the tank is actually full.
