Tellthemride
- Oct 6, 2019
Actually, nothing was debunked. If I shut the car off with the windows open and don't touch anything (didn't touch the Start button to turn on Accessory Mode or touch the brake), the warning keeps flashing.
When you shut off the car, accessory mode is on by default. Doesn’t matter if your radio is on or not, doesn’t matter if you didn’t press the start button once more after shutting the engine off. Power to accessories still on. Open your door and then close it. Your problems will go away.
