Truxxx lift installed by local wheel/tire shop for 3 hours labor plus alignment. Said it was a simple install. They recently did my brother's Atlas which was 6hrs labor. (Dealer where I purchased said they wouldn't do the install.) I left the rubber spacer at 100% in the back (I believe the instructions mentioned custom cutting if desired), and both front and back from center hub to fender are now 2" taller. So not sure I did any "leveling" in the process.
Went with the Toyo A/T IIIs on stock SX 20 inch rims. 255/55/20. I have the factory installed splash guard kit and immediately had a tiny rub on the front guards at certain turning points. Not really noticeable and imagine this will go away as tires and/or plastic wear down. Definitely couldn't go any bigger. Before and after pics below. To me, "after" looks like what it should be and "before" is a slammed version.
View attachment 10898View attachment 10899
This is what I'm after. We basically have the same telluride. HA
Edit- ihatch - do you have the self leveling rear shocks?
